Buick Tensioner Pulley Swap: PICS!!!
Old 05-02-2012, 01:57 PM
sjsingle1's Avatar
got a P/N for the pulley?
Old 05-02-2012, 02:24 PM
Mighty Whitey's Avatar
Not right off hand, we just had a stocker laying around a buddy's shop after he installed a magnacharger on a customer's '10 Camaro SS, which replaced the stock pulley with something else I assume (never looked under the hood to see)
Old 06-10-2012, 10:25 AM
86lxnotch's Avatar
just a fyi for whoever is interested i bought the dayco tensioner this morning and was gonna get the buick pulley right away.....turns out they must know of the issue because the pulley on the new tensioner was the same exact pulley as the buick one. i confirmed this after i got home and saw that the new one is def a little larger than the oem pulley that i took off
Old 06-10-2012, 04:22 PM
86lxnotch's Avatar
Dayco 89253, advanced and $37 n change
Old 06-10-2012, 04:57 PM
ramairetransam's Avatar
Thank you kindly
Old 06-10-2012, 07:07 PM
86lxnotch's Avatar
not a problem! figured i would relay the info since i found it here to start with
Old 06-14-2012, 07:03 AM
just a question , that part number is wrong , im checking and its not coming up for my 99 formula.
Old 06-14-2012, 10:09 AM
86lxnotch's Avatar
Sorry that's what I got for a truck tensioner
Old 07-22-2012, 12:00 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
I just checked on the price of a 2010 Camaro tensioner and it's $120, so that's a waste considering a Katech is less.
So let me ask this, when you put the pulley on the tensioner, I forget, is there a washer that goes on the back or just the front?
Old 07-23-2012, 01:15 PM
DopeFedZ's Avatar
This is the one I have been running never had any issues since I started using it over a year ago.
http://www.ebay.com/itm/LS1-LS2-LSX-...d47881&vxp=mtr
Old 05-07-2015, 06:30 AM
87dimeblazer's Avatar
BFTD
Did this the other day. After my P/S pump & Alt relocation, the serpentine belt was about 1/4- 1/2'' too large. I grabbed two belt sizes down from the stock belt length and both were too small (of course). So dredging though threads I found this. The pulley was just right. Still part number 89009 and made by Dayco. The added bonus is that the pulley has been "altered" since this post. Absolutely no grinding required. Pull the old one off and put the new one on.
Old 06-14-2016, 01:31 AM
  #32
DOUBT IT's Avatar
Originally Posted by 87dimeblazer
BFTD
Always good to still see people helped by my old posts.
Even better to see that it's someone local to me.
Old 06-14-2016, 09:33 PM
  #33
01ssreda4's Avatar
On an fbody no washer on the back.
Old 06-15-2016, 04:51 PM
  #34
"I MAID THEESE"
Mavn's Avatar
What is the purpose of this?
Old 06-15-2016, 04:54 PM
  #35
ericwilloughby's Avatar
Keeps the belt from flying off as easy. The larger diameter helps and the shoulders are higher
Quick Reply: Buick Tensioner Pulley Swap: PICS!!!
