need to replace drivers side cat?
Old Jul 16, 2007 | 02:54 PM
98WsSick's Avatar
Default need to replace drivers side cat?
brought my car to the exhaust place because i need my drivers side cat replaced and they said $300, because they need to order another stock one because the 3 bolt flange. Is it possible to weld in a high flow cat there without moving the spot of the cat? or do i need to replace it with a stock one? thanks
Old Jul 16, 2007 | 03:15 PM
turbowhistle86's Avatar
how many miles are on the car? As long as its less than 8 years old and under 80,000 miles, its covered under GM's warranty. I just had both cats on my 02 Z28 replaced for free.
Old Jul 16, 2007 | 04:03 PM
kyemt's Avatar
Default car
the car in his sig is a 98 so id say hes out of warrenty
Old Jul 16, 2007 | 04:06 PM
tylerdj's Avatar
They extended the warranty to 10 years / 120K miles on the cats.
Old Jul 16, 2007 | 04:15 PM
2001NBMZ28's Avatar
I'm confused - sig also says Flowmaster+high flow cats....
The 10year/120K extended GM warranty is only on the 00-02 cars.
Old Jul 16, 2007 | 04:27 PM
98WsSick's Avatar
i lied in my sig, i have 1 high flow cat, other is stock and is the clogged one. My cars a 98 so its not covered in the warranty, i have just under 100k. so can i replace it with an ebay highflow cat somehow? or does it need to be stock?
Old Jul 16, 2007 | 10:52 PM
98WsSick's Avatar
does anyone know? i dont wanna spend $300 if i dont need to
Old Jul 17, 2007 | 08:36 AM
tylerdj's Avatar
An exhaust shop should be able to adapt a hi-flow cat in there.
Old Jul 17, 2007 | 10:06 AM
madmatt's Avatar
Hmm, my dealership said my 2000 only had 8 year 80k when they replaced the cat yesterday. Ill have to ask them about it if (when) the drivers side goes out.
Old Jul 17, 2007 | 10:09 AM
kyemt's Avatar
Default cat
a good muffler shop should be able to repalce it with a high flow may have to take it off to do so, is the drivers side the one thats real close to the manifold?
Old Jul 17, 2007 | 10:13 AM
proporio's Avatar
Exhaust shop should be able to adapt a cat on there for you, or try ebay, they always have stock cats listed for sale.
I have the ones off my car sitting in the garage, if you want to buy it let me know.
Either way, good luck.
Old Jul 17, 2007 | 12:12 PM
PureWS6's Avatar
At how many miles did you cat take a crap on you?
