about to do headers....what else do I need?
Old Jul 19, 2007 | 09:25 AM
turbowhistle86's Avatar
Default about to do headers....what else do I need?
I am about to order Hooker LTs...what else do I need to make this install a snap? Here's my partial list:
obviously...the headers!
stage 8 locking bolts
MSD wires
do I need new tranny/motor mounts? the car has 45K miles and its an A4
what is the official part # for TR55 plugs?
reuse stock header gaskets or get fancy ones?
I am building a custom TD setup, so I will mess with the rest of that at a later date.
Old Jul 19, 2007 | 09:29 AM
tylerdj's Avatar
You will need some O2 sims (unless yours are tuned out) for the rear O2's and either a pair of Bosch 13111 O2's or a set of O2 extensions for the front O2's.
Old Jul 19, 2007 | 09:30 AM
I've got a Predator, which I am told will tune out the rear 02s....where do I get the extensions for the fronts?
Old Jul 19, 2007 | 09:38 AM
tylerdj's Avatar
I believe several sponsors sell them -------> Texas Speed, Thunder Racing, Speed Inc, WS6 store, etc.
Old Jul 19, 2007 | 10:38 AM
EarlSS's Avatar
I bought new gaskets from GM cause they aint expensive and i didn't want to risk a leak from reuseing my gaskets.
Old Jul 19, 2007 | 11:39 AM
CockerKid009's Avatar
Is it just me or do not all exhaust setups have rear o2s
Old Jul 19, 2007 | 11:53 AM
EarlSS's Avatar
I'm also gonna use my stock bolts for my install.
Old Jul 19, 2007 | 11:56 AM
MikeD101898's Avatar
If it's stock it does. If not stock, someone might have already tuned them out.
Old Jul 19, 2007 | 06:29 PM
lastcall190's Avatar
Link in sig that covers a few things. IMO you don't need the Stg8s, just clean/reuse the stock bolts or get some ARPs. Stock header gaskets are fine (get new ones if your's look like they've been through hell). Good luck.
-J
Old Jul 19, 2007 | 08:02 PM
hammerhead's Avatar
MSD wires
I used:
Percy's aluminum gaskets
LS2 manifold bolts with anitseize
MSD wires / AC Delco iridium plugs
I also had to get some new 02 sensors because they either stripped or wouldn't come out. You might also need a small hack saw (or Sawzall) to remove the casting tab on the driver's side of the block.
I sent my computer to Wait4me for the tune.
