Map sensor in FAST intake
Old Jul 22, 2007 | 11:00 AM
kkslds's Avatar
Default Map sensor in FAST intake
I pulled the map sensor off my stock manifold and went to put it in the fast and it goes in fine but it's kinda loose. Is there a new grommet i can buy or will it be fine. it stays in ok but i dont know how much pressure builds up in there and i dont want it to blow out or anything if it is possible. Any ideas on what i need to do? thanks
Old Jul 22, 2007 | 04:05 PM
MorePowerPlease's Avatar
You would have to buy a new map sensor to get the gromet (about $35).
They are not the tightest fitting gromest to begin with. I did my swap I used the one from my stock intake and have not had a problem. I would keep a eye on it and replace if you need to.
Old Jul 22, 2007 | 04:15 PM
ls2 bait's Avatar
i put sensor safe rtv on mine when i put it in as it was loose. havent had a prob yet.
Old Jul 22, 2007 | 04:37 PM
kkslds's Avatar
I guess ill be gettin me some sensor safe rtv then. thanks guys
Old Jul 22, 2007 | 04:38 PM
ringram's Avatar
+1 blob some rtv around it and sit it in. Let it cure so its snug, seems fine for me too.
Old Jul 22, 2007 | 05:17 PM
TheBlurLS1's Avatar
That's what she said...
You can buy a new grommet for like $5 at the stealership, it will stay in a lot better. The new FAST intakes are coming with a "revised" MAP hole, my friend just put one on.
Old Jul 22, 2007 | 09:28 PM
405HP_Z06's Avatar
GM Part # 16194007 - Seal, MAP Sensor, List $5.22
Old Jul 22, 2007 | 09:29 PM
405HP_Z06's Avatar
Is this identified by 'Revision J' cast into the upper?
Old Jul 22, 2007 | 10:46 PM
Sluggish's Avatar
I don't remember seeing a J on there. But the sensor fit into it great w/ the old grommet.
Old Jul 23, 2007 | 06:17 AM
JakeY2KZ's Avatar
I bought a new seal for the MAP when I put my intake on. I don't think it helped much at all so I used some rtv also. Made it a lot better. Just make sure it dries before you put the intake on.
Old Jul 23, 2007 | 09:23 AM
TheLS1Kid's Avatar
I just pulled it out of the old manifold, cleaned the grommet, and then stuck it in the FAST with no problems. It felt snug to me.
Old Jul 23, 2007 | 10:34 AM
kkslds's Avatar
mines fairly snug too. but i want it in there good. mine has the j casted beside the hole. I just went ahead and got the sensor safe rtv.
Old Jul 23, 2007 | 10:39 AM
kkslds's Avatar
problem solved
