Any way to fix or do I need a new block? (pics)
Old Jul 27, 2007 | 04:38 PM
lsone2001's Avatar
Question Any way to fix or do I need a new block? (pics)
I guess the starter motor has a little more torque than I ever imagined. Before anyone says anything, I know I should not have tried to start a suspected locked motor.
Attached Thumbnails Any way to fix or do I need a new block? (pics)-start1.jpg   Any way to fix or do I need a new block? (pics)-start2.jpg
Old Jul 27, 2007 | 04:46 PM
Sluggish's Avatar
You maybe be able to weld the piece back on. Then drill it out and Heli-coil it.
Old Jul 27, 2007 | 05:22 PM
SoCalZ28's Avatar
sorry to tell you man, your probably going to need a new block. Thats a critical bolt.
Old Jul 27, 2007 | 05:24 PM
Mike94ZLT1's Avatar
Holy ****... I would have thought the nose would have broken off the starter before that would have happened... Is that a stock starter?
Old Jul 27, 2007 | 06:08 PM
lsone2001's Avatar
Yeah, its stock. I figured it would've strip the teeth off before that happened or burnt the motor or something, anything but this.
Old Jul 27, 2007 | 09:53 PM
NHRAFORMULA00's Avatar
just have it welded back together, no biggie.
Old Jul 27, 2007 | 11:09 PM
AutomagicLS1's Avatar
This happend when my motor hydrolocked
Old Jul 27, 2007 | 11:22 PM
fuseone's Avatar
how did you guys hydro lock you're engine?
Old Jul 27, 2007 | 11:32 PM
delsold's Avatar
sorry to hear that...you may be able to weld/helicoil, but im not sure if it'll work
on a less serious note- someone should take on of those pictures and make one of the motivating pictures that says "my starter motor produces more torque than your 4 cylinder"
Old Jul 27, 2007 | 11:44 PM
tj1986c's Avatar
Old Jul 28, 2007 | 01:45 AM
99NMB's Avatar
My starter has had a broken tab where it mounts for over a year now, never given any problems, i just tightened the one bolt up real good...
Old Jul 28, 2007 | 04:53 AM
Black FormulaLs1's Avatar
when i got my 99 formy and got a chance to get underneath her i noticed that soembody had slagged the starter bolt hole on the block...but it NEVER gave me any troubles..ever...
Old Jul 28, 2007 | 09:44 AM
kyemt's Avatar
Default motor
if yoru rebuliding the motor when u get the block apart and take it to someone with a tig welder and have the weld the parts back on and fill the holes up with weld, then be sure to mark the holes correctly and redrill and tap them
