New Typhoon Intake?
Old Jul 27, 2007 | 05:45 PM
transamman400's Avatar
Default New Typhoon Intake?
Any experience with this intake? And how comparable is it to the FAST 90? Is it somewhere between the LS6 and the FAST? I see it can be used with a 96mm TB so I was just wondering if that had any benefit over the FAST.
Old Jul 27, 2007 | 07:32 PM
MVDCGTO's Avatar
A local guy around me has a '04 LS1 GTO and he installed the typhoon intake because he is building a race/show car and the typhoon is pretty. Long story short he lost over 15 rwhp compared to the LS6. From what I understand it can be ported to flow better but it still is not a good design.
Old Jul 27, 2007 | 08:39 PM
Asmodeus's Avatar
Hmm.. that's odd, maybe he messed something up?
I have one with my heads/cam combo and the damn thing pulls like a train up top, but I did everything at once. Another member here installed one, craz1469 is his name, and noticed a seat of the pants difference over his LS6 intake at higher rpm's. Professional Products' website claims a 17hp gain over the LS6 at 6500. They got a bad rap because of it not sealing and the fuel lines leaking but they have addressed those problems. The guy with the GTO is the only one who has posted that he didn't get any gains.
Old Jul 27, 2007 | 08:59 PM
Silas2k's Avatar
actually, months ago i saw at least 2-3 people post dynos with them losing power with a stock ported tb/typhoon over their original stock ported tb/ls6... at the time PP hadnt come out with their throttle body and the general consensus was that maybe itll work better paired with their tb... but i never followed up past that... does anyone have dyno results for ported stock tb/ls6 and PP tb/PP mani?
Old Jul 27, 2007 | 09:01 PM
Asmodeus's Avatar
I did a search and I didn't find those people you are talking about.
Old Jul 27, 2007 | 09:11 PM
Silas2k's Avatar
since the search is so fubard lately i wouldnt doubt it... i really wish i would have saved those threads, im not trying to be confrontational or anything, because i have the ls1 intake so im not trying to be manifold loyal or anything
Old Jul 27, 2007 | 10:28 PM
chae's Avatar
I've got one of the threads saved. I'll post it in a few minutes.
Old Jul 27, 2007 | 10:41 PM
chae's Avatar
https://ls1tech.com/forums/showthrea...hlight=typhoon.
red = after heads/cam, headers/exhaust
blue = after heads/cam, headers/exhaust, 85mm PP intake manifold, 85mm PP throttle body
Little to no gain at all over the LS6 intake manifold.
Originally Posted by dan_e
Obviously no gains, and if you consider the tuner picked up about 10 whp, you may even say it lost power
Note: Please disregard the green pull because it is just a baseline run. The real comparison is between red (heads/cam/headers/exhaust) vs. blue (heads/cam/headers/exhaust/85mm PP intake manifold/85mm PP throttle body)
Old Jul 28, 2007 | 12:44 AM
Silas2k's Avatar
ohhh now i remember the reason i stopped following the PP stuff... every single test was done on big ci motors, or h/c cars... there was no full bolt on results...
Old Jul 28, 2007 | 01:42 AM
Asmodeus's Avatar
If it's the same as the LS6, then fine.. I had to upgrade from the LS1 anyway and it looks better and has new and better fuel rails. However, myself, my mechanic, and a couple I've talked to are convinced it pulls a little more HP up top. The graph you posted looks like his was even a little better down low over the LS6.
Old Jul 28, 2007 | 05:05 AM
chae's Avatar
That was assumed to be picked up from the tune.
Old Jul 28, 2007 | 11:53 AM
chae's Avatar
Funny how all these PP threads die down after that graph is posted
Old Jul 28, 2007 | 12:59 PM
Asmodeus's Avatar
It's one graph, it really doesn't mean a whole lot.. the threads die because no one has much experience with this intake.
If you can "assume" the tune picked up the midrange (with a richer A/F ratio too), then you can "assume" that it only did the same as the LS6 up top.
Just keep on assuming!
