Normal FAST vs ported FAST
Old Jul 30, 2007 | 05:38 AM
Formula_Power's Avatar
Default Normal FAST vs ported FAST
is it really worth it to pay 200 dollars to get a fast 90mm ported? Does anyone have any before and after track times or dynos
Old Jul 30, 2007 | 02:34 PM
so has there never been a test with between the 2?
Old Jul 30, 2007 | 02:36 PM
ONEBADWS6's Avatar
To port it right your going to pay alot more than $200. I have 4 1/2 hours of porting in mine.
Old Jul 30, 2007 | 03:02 PM
oh...i had seen 200 posted before so that was what i used
Old Jul 30, 2007 | 04:26 PM
ONEBADWS6's Avatar
I think most guys charge $350 and up.
Old Jul 30, 2007 | 04:31 PM
VH5150's Avatar
Dynojet Fan
4 1/2 hrs...wow, any pix... of what you did??? curious to see what you did if you dont mind...
Old Jul 30, 2007 | 06:58 PM
slow trap's Avatar
i (think) gains are around 7-10 rw but that is just a ballpark guess. someone may pick up more and some may pick up less,maybe alot less. i think a bigger cube mill would really benefit from porting but that's just my opinion which don't mean much .
Old Jul 31, 2007 | 12:21 AM
Spiral04's Avatar
I believ Tony Mamo of AFR charges close to $500 to port them. I do think that all port jobs are not the same. The most effective way would be to have them port matched to your heads. It would be nice if there was a thread that compared many port jobs on the same car (ie Vengeance,AFR,TEA,etc.)
Old Jul 31, 2007 | 12:41 AM
VH5150's Avatar
Dynojet Fan
That is outrageous..way too much money....
Old Jul 31, 2007 | 10:11 AM
ONEBADWS6's Avatar
I didin't take pics but if you open one up you wonder why you just paid $850 for this thing. Not only did I open up where the intake meets the head a ton, but the divit in the top of the intake protrudes into that runner. I ground it flush with no problem. If you look at the ridges on the plenum side of the ports thats where I spent about 2 solid hours smoothing everything out. I put it on my bolt on car with a cheater cam and picked up 2.5mph over a LS6.
Old Jul 31, 2007 | 10:26 AM
radkon's Avatar
Anyone else wonder why FAST doesn't modify the original mold to get rid of that divot and the ridges?
Sorry to post off topic...
Old Jul 31, 2007 | 10:55 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Depending on your setup, the more radical, the more it will gain, if your buying one, just have it ported then so its cheaper in the long run, Vengence has a deal thats a killer one in the sponsor sale section. if I really wanted one, id contact them for the price.
Or get one for a good deal and plan on sending it out later, thats the other option.
Old Jul 31, 2007 | 04:56 PM
carreras's Avatar
Maybe this will help w/ ur decision
https://ls1tech.com/forums/dynamometer-results-comparisons/755933-there-any-before-after-ported-fast-90mm-dyno-graphs-out-there.html
Old Jul 31, 2007 | 07:24 PM
studderin's Avatar
to get the part out of the mold
Old Jul 31, 2007 | 09:36 PM
VH5150's Avatar
Dynojet Fan
I get it but I dont get it...still need pix but its ok...
Old Jul 31, 2007 | 09:58 PM
Camaro01SS4life's Avatar
https://ls1tech.com/forums/showthread.php?t=755933
I think its well worth it...500 bucks for more power all through out the RPM band...Netting about 25RWHP up top is well worth it IMO...
Look at it this way...You pay about the same amount for headers for similiar gains...And these gains are over an already well designed intake manifold...
Give Tony Mamo a PM or other vendors that can port a Fast unit for ya...
Kev
Old Aug 1, 2007 | 08:09 AM
radkon's Avatar
Ah, there has to be a way to do it. They're just lazy
