OMG How to get the second motor mount lined up?
Old Aug 3, 2007 | 07:14 PM
IHeartTurbo's Avatar
Originally Posted by Jimmard
Can prying hard enough to get the bolts to line up slightly throw off your front alignment? After I put mine in, my steering wheel is slightly turned to the left and pulls ever so slightly. Makes sense if you had to move the motor mount a 1/2 inch that it would slightly throw off the alignment.
Moving the motor won't effect your alignment unless you hit/bent the rack, which would be pretty hard.
Old Aug 3, 2007 | 08:26 PM
0utLawZ28's Avatar
when i pulled my motor i just pulled the 2 bolts out when i went to drop it back in lined 1 up put the bolt throught then lined the other 1 up
Old Aug 5, 2007 | 07:49 PM
hammerhead's Avatar
I bought some Prothane mounts, but I decided not to install them when I found out what was involved. My stock ones look fine and I have no issues with vibration or banging with the AR headers installed. Maybe down the road I'll replace them if necessary.
Old Aug 5, 2007 | 08:14 PM
cobrakiller221's Avatar
It took me 20 hours to do the headers and poly motor mounts. all I can say is get a strong pry bar and some patience. good luck
Old Aug 5, 2007 | 10:40 PM
Wino's Avatar
I had a couple guys helping me and we still had to use a 4' jack handle to pry the motor in place to get the bolt lined up. Zero fun.
