OMG How to get the second motor mount lined up?
So we're in the middle of my motor mount/exhaust install and we've got the driver side mount in and fully bolted up.
This morning we got the passenger side mount bolted to the block, but I can't for the life of me get it lined up with the pedestal so as to push the through bolt in!
The mount is positioned about a 1/4" exactly to the left (toward the passenger side) of where it needs to be.
Any tips on how to line it up? And yes, we have a copious amount of prybars so don't just say "PRY THE SH*T OUT OF IT" because we've already tried.....
So long as you make sure each mount has the tabs pointing up and the poly is in the shell correctly, the two are interchangeable.
I think?
We got it. It took unbolting the pedestal and re-unbolting the clamshell plus some swearing and brute force but it's in and I swear I will never do this again in my life.
Well, maybe......lol
I just did my headers and they were CAKE. Ground the tab on the driver's side a tiny bit and it slid right up no problems. I think the poly mounts make the engine sit a little higher and it's definitely stiffer.
When I saw my passenger side was off by 1/4 inch, I took the mount back off, put it in a vice and pushed the metal bolt shaft in the middle through the mount 1/4 inch. It lined up perfect after that.
Changing the actual mount only took me a few minutes. I spent much more time getting the AC/starter off and on than I actually spent with the mount.
