separate radiator for the 4a ?
Old Aug 3, 2007 | 10:29 AM
Flyman's Avatar
Default separate radiator for the 4a ?
can I cool my 4L60E (4a) with a B&M remote radiator that has an electric fan with thermostat, only.
I want to increase my surface area for cooling the engine by dedicating the entire radiator to the engine.
Thanks
Old Aug 3, 2007 | 11:53 AM
jimmyblue's Avatar
Moderator
There are coolers with the fan already attached, and making
your own would just involve a couple of 12VDC muffin fans, a
thermostat and a little sheet metal shroud cobbling (about $20
- $30 all told, on top of the cooler itself). If you still shed trans
cooler heat into the radiator air path it's probably a zero-sum
game though, other than less of a radiator airflow blockage.
Wonder about using one of those frame-rail (long, skinny) coolers,
and cut a slot in the chin spoiler to feed it. That would work pretty
well for rolling, dunno about parked. But get the hot exit air off the
radiator/condenser stack.
With its own fans you might be able to make it draw from the chin
hole, but dump elsewhere.
Old Aug 3, 2007 | 12:30 PM
Flyman's Avatar
I guess the real question is......Is this bad for my transmission? Will my tranny still perform the same with no damage in summer or winter?
Old Aug 6, 2007 | 08:08 AM
Flyman's Avatar
Btt....
