Victor Jr EFI vs. Fast 90
#41
All I can tell you is that on my 416" stroker, I made better power with the FAST on top of good heads and a single pattern 254/254, 599/599 112 +3 stick.
If you are only spinning it to 7000(which I am), I'd go w/the FAST. My junk comes in at 3555 #'s wet and I just wasn't willing to give up what was lost down low to gain only half of it back spinning to 7500+(again, on MY application). I wanted all the tq. I could get down low to get this tank off the line hard.
You say your RW will be light. Imagine stump pulling tq./and very respectable rwhp ALL THE WAY to your shift points in a light car.
Traction problems can be dealt with, and once they are, insane 60' numbers should be the norm.
JMHO..... but again, as was previously mentioned, others with the "right" cam/TB are doing well with the jr.(and are generally on larger ci's 400+).
Maybe you should consult VH5150's experts for the right answer?
Good luck w/the build!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#42
Originally Posted by VH5150
actually I have been around for quite some time now, just never signed up...
I might not be an expert, BUT the people who help me with my car ARE. They have way more experience then ron or anyone else who has posted on this thread....INCLUDING TONY MAMO...
see you at the track soon ron.... Ill be sure to call you... Im in florida...
The Vic Jr LS1 intake is not a very effective piece IMO....besides the obvious shorter intake runners there really isnt very much trick about it. An LS1 is very similar to a SBF in alot of respects concerning port relationships (sorry guys....its true). You want to see a bad *** single plane intake for a Ford SBF that an LS1 intake could practically be copied from, check out the Parker Funnelweb intake.
http://parkerracing.com.au/funnelweb.html
Its bad to the bone and is very effective on the dyno and out in the field (the two go hand in hand about 99.9% of the time). Its tall, has ample runner cross section to be very effective at high RPM, a clover leaf plenum to remove some of the dead air space (in a carb application), extended runners for more TQ.....its just a well designed intake manifold.
Also, If you decided to use the search feature to investigate some of my other comments concerning this intake you will see that the main problem with it for most of the crowd reading these threads is packaging....meaning that without a fairly abrupt 90' elbow, you wont fit the intake under the hood unless you run a 4" cowl etc. The air rushing foward doesnt like making an abrupt 180" turn to feed the front bank of cylinders and makes the intake that much less effective at the RPM level your jumping up and down saying how well it will work. Plus the intake runners are too small and have absolutely zero taper which is always preferred (ask your engine buddies uncle's nephew about intake runner taper).
Lastly, a properly ported FAST is a pretty impressive piece all things considered....helps the engine generate a fair amount of low end TQ, great midrange grunt, and the right package can still shine even in the 7000-7300 range.
Note the engine dyno results attached below of my 383 CID 11 to 1 solid roller engine. And this is with a small solid roller with only a 242 intake lobe. With another 10 more degrees at .050 the top end charge of this combination would have looked even better.
![](http://ourworld.cs.com/ls1info2/383+with+242+SR+Shaft+Rocker.jpg)
Next time try to peddle your thoughts and ideas on their own merit....not by trying to pick out some of the more respected members on this board. Or better yet, have your friends Uncle post himself and try growing up a little.
By the way, this post is for the benefit of others reading this trying to get a better handle on things....not to try and sway you and all your experts.
Tony M.
#43
my opinion to the original poster being i had/have both. for a non FI car go with the FAST 90. my 408 longblock was built for FI and so was the cam, and this setup loves the gmpp carb style manifold. idles and runs much smoother than the FAST90. but take that for what it is.
as they say you will lose tq down low with the carb style manifold, but for me having 460tq at 3000rpms is still too much tq
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#45
Super Hulk Smash
Well I guess the only way to find out for sure is to take the car or car's to the track... MPH is power, not what some stupid dyno sheet says....
#46
Originally Posted by JakeFusion™
Tony has a full and I mean full weight C5. What is it Tony, like 3600lbs with the stereo gear? And it ran an impressive number at the track 11 @ 128.6 MPH. That seems like pretty decent power to me with an IRS. Link here.
#47
Super Hulk Smash
Yep nice car for sure... But my 346ci a4, ls6 head, c5 ran 11@122 so whats youre point... oh wait im just some dumb backyard ls1 person....
#51
Originally Posted by PowerShift408
MPH = Horsepower, I mean you said it.
So you're down 7 mph... Good argument.
Why dont you ask what I have before you make a stupid comment....
![Mullet](https://ls1tech.com/forums/images/smilies/mullet.gif)
#52
Correct.... 346 vs 383.. well I would hope a 383 would mph more than my setup... yep 7 mph less w/ a nitrous tune, 1 7/8th headers, big 3in exhaust, 4500rpm stall, heads ported for nitrous, ect.... shall I go on???
Why dont you ask what I have before you make a stupid comment....![Mullet](https://ls1tech.com/forums/images/smilies/mullet.gif)
#53
What is the better option for motors that are going to be sprayed with large N20 shots? I currently have the VJ intake and NW 90 TB on my 408 and previously had the FAST 90/90 on my H/C LS1. I was told to expect some loss NA but once the car is sprayed the VJ will be a much better choice. Kinda in the same boat...dunno whether or not to stay with the VJ.
#54
Super Hulk Smash
#56
under 400 cubes and as a mild strret setup stay with the Fast 90. My 402 is by no means mild (14.5-1 compression, 258/262 on 110 cam, 280 cranking compression). With the Fast I cut a 1.33 60ft as a best and best mph of 133. With the Vic I cut a 1.29 and trapped at 137, and thats HP-HP runs. I know it works for me. Will it work for otheres? If your setup is agressive enough yes. Otherwise you will be slower with the Vic. As for FI setups the vic jr will win every time. I agree with Tony, the out of the box Vic sucks. The runners are like straws and have no taper. When I opened my stock Fast all I could think was what a piece of junk and I can't believe I payed $800 for this. 5+ hours of porting I had a very nice intake. But after 5 hours of porting, the Vic jr flowed more. This is just my experiance take it for what it is worth.
#57
The reason I am not more straight forward with the purpose of this car is because taking things to the street is generally looked down appon in this forum.
#59
How in the hell do you port heads for nitrous? Maybe you can enlighten Tony...
