Victor Jr EFI vs. Fast 90
#62
In my opinion this is a case where the hardcore drag racers have done more testing than the shops (that sell to the average guy) have. Yeah maybe a few tests are run back to back, but without due time dialing in a combo, it's not a fair comparison. There is tons of research on cam profiles that work well with the LSX style intake, but not necessarily the carb-style or sheetmetal. I'm sure the cam profiles for a fast won't optimize a carb-style. And some of the direct comparisons are a PORTED FAST vs. BOX STOCK VIC, and thats not really fair either.
I don't really expect a manufacturer or tuner like AFR to find the best combo for a Trickflow head in the same sense the mainstream porters of the Fast 90 to dial in a carb style or sheetmetal intake setup.
#64
Damn I don't have either one! But I know which one I think I could paint black and still pass emissions. I mean y'all a talking the only time your car is street legal is when you have it on the trailer pulling it to the track. There is really only one choice for a duel purpose late model Camaro. If I ever win the lottery I'm going to get Tony to port me one up. Thoses coil covers with your logo on them are bitchin Ron.
#66
2c5s took a cleaned up FAST (not fully ported by myself) and tested it against a lightly cleaned up Vic Jr with a 90' elbow (the biggest drawback of that style intake) and on a fairly good sized engine (402 CID) that made in the low 500's to the rearwheel (obviously a healthy appetite for air) lost 40 ft/lbs or TQ and lost 10 rwhp. The single plane showed a loss at every RPM point, and was really soft in the lower part of the curve.
Assuming the need to run a 90' elbow for fitment reasons, on most street/strip LS1 engines regardless of displacement, my contention is still firm that a ported FAST is simply a better overall piece in most applications. There are always exceptions to the rule, but I bet you nine out of ten people reading this considering the swap would not only ET and go faster with a properly modified FAST, but also have a significant increase in the bottom end (beneficial to a street car) due to the longer runner design. A heavy car (think F-Body) will benefit even more from the improved low amd midrange grunt helping it to 60 foot and get out of the hole with alot more authority.
Perhaps Chris (2c5s) will see this and respond as well...
Regards,
Tony
Regards,
Tony
#67
9/10 cars might be better off with the fast 90. But the fastest cars 9/10 might be better off with a carb style or sheetmetal if it's all out setup. A guy that is driving his car once out of every two weeks with thousands of dollars dumped into his setup probably isn't really a daily driver and low-end torque and driveability aren't his primary concern, it's ET.
#68
I agree with you guys. But at the power level I'm at I did not notice the TQ loss as my 60ft improved. Do I drive the car daily, no. Can I? Yep. Bottom line is unless you have a high winding max effert N/A motor or a FI setup stay with the Fast. Tony port a Vic jr and flow it, you'd be supprised.
#70
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Tony/Ron: I have a similar question to above...does all of the Fast v. Victor argument go out the window when we discuss forced induction? I am currently running an unported Victor w/elbow on my turbo 408. Looking at the graphs posted, I'm wondering if I am not leaving 50hp/tq on the table with my setup...or if it does not apply in my application?
![](http://i15.photobucket.com/albums/a394/GTOzlla/IMG_1528a.jpg)
#71
Looking good by the way....do you have a gragh of your current results you can post?
Regards,
Tony
#73
Originally Posted by JMBLOWNWS6
Im thinking the vic jr will be a better choice. Ill have LME port it ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Good luck either way....obviously if your still considering one of my intakes drop me a phone call or a quick PM.
If any of you boosted guys want to try both and have the ability to provide me with back to back dyno numbers I might be up for loaning you one for the test. Don't forget work would be involved more than likely with fabbing two different inlets due to the different TB locations. Of course in the end you would only pay for the ported FAST if you were happy with the results. Again, PM me if that is a feasible situation for anyone so we can further discuss the details.
In fact I would consider the test with anyone running a Vic Jr N/A.....Im more confident I wont see that FAST back in that comparison.
Thanks,
Tony
#75
Originally Posted by Tony Mamo @ AFR
I know of a couple of people running my ported FAST at 15PSI without issue (and making big power), and honestly I doubt another 5 lbs would create one, but at some point a solid chunk of aluminum would be better at extremely high levels of boost (versus the three piece plastic intake).
Thanks,
Tony
Thanks,
Tony
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
#77
Im going to run a vic jr! My friends 408 with trickflow heads picked up 18whp over the Fast setup! But all cars are different! I saw this in person so I'm sold! As far as low end torque he has a 4,000 stall so not worried about it. On ther other hand vic jr cheeper and it looks better LOL ![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
The only i would get a fast is if i got it on a good deal
#78
Thanks,
Tony
Thanks,
Tony
#79
I have a unported fast and a unported vic jr w elbow. You willing to port both? Then we can make a deal via pm's on the port work? LMK and I can get the items to you ASAP. Test car will be a 2003 corvette LME 402,Novi 2000 etc. Car has allready been in the 800's.
Tuning will be handled inhouse and intakes will be swapped on the dyno ![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Lets see if Mr. Mamo comes through... or possibly Ron...
This will put the debate to rest once and for all...
JM, I dont think
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#80
JM, I dont think
tony will port the intakes for free do you....?? ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
JM, I dont think
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
