Header gasket layers separating
Old Aug 6, 2007 | 05:49 PM
lovin myls1's Avatar
Default Header gasket layers separating
Was planing on reusing my origanal gaskets as many members have done but found it's made of layers and on one side the layers are separating.You guys that reused yours,were they doing this?
Old Aug 6, 2007 | 06:26 PM
sroach20's Avatar
i used a felpro set. they are multi layer steel and are only around $10-11. why take the chance when they are so cheap?
Old Aug 6, 2007 | 06:31 PM
10SecDreamer's Avatar
Where did you order them from?
Old Aug 6, 2007 | 06:32 PM
Yeah,your probably right.Just wondered what everyone else experienced because they dont look bad.
Old Aug 6, 2007 | 06:49 PM
sroach20's Avatar
oreilly or vautozone.
Old Aug 6, 2007 | 09:03 PM
Cruz28's Avatar
I bought new original gaskets at the dealer, no leaks. Don't remember how much they were, but I know they were cheap. It's not worth risking having to take everything apart again because you reused the old ones. Good luck.
Old Aug 7, 2007 | 09:39 AM
mcamarols1's Avatar
percy seal 4 good, are what i used
Old Aug 7, 2007 | 10:20 AM
A-Dub's Avatar
I reused my factory units even though they were in bad shape. They leaked. For as cheap as they are, just replace them now.
FWIW, I just replaced the factory ones with the gaskets that came with my Edelbrocks, no leaks so far
Old Aug 7, 2007 | 07:47 PM
After some calling,found the Fel Pro for about 12.00.Auto Zone and Advance Auto didn't have them in stock as well as the two local GM dealers.Wasn't worried about the cost, just didn't want to get held up on the job.
As it is, I got both sides on and the fit is great.Couldn't get my torque wrench in there though,had to just guess but I do have locking bolts.Hope to be done tomorrow.Thanks for the replys!
