RPMs hanging after Ported TB
Old Aug 7, 2007 | 09:29 PM
SupermanSS's Avatar
Default RPMs hanging after Ported TB
Not sure if it has anything to do with the TB being ported which Bo did a freaking awesome job on by the way...thanks again man. Anyways now when im coming to a stop the RPMs will hang at like 1500 sometimes even go up and then will finally after i completely stop moving drop back to idle at 900. Sometimes it will hang at 1100 or 1000 then drop when completely stopped. Any ideas?
Old Aug 7, 2007 | 09:33 PM
ErikElvis's Avatar
Hey where are you at in ol DE? Anyway have you just put it in and started driving or has it been doing it for a bit? If you just installed it it may just have to relearn the idle.
Old Aug 7, 2007 | 09:38 PM
styoung's Avatar
mine stays around 1200 i dont know who ported it but it does that when i coast to a stop.
Old Aug 7, 2007 | 09:39 PM
SupermanSS's Avatar
Im in good ol HarrENTUN or Harrington for non rednecks haha. No its been on the car for about 2 months and I was hoping that it would stop after the dynotune but no dice. I thought that my microswitch was snaggin it but i checked and it doesnt seem to be hitting. I guess I could try an idle re-learn again but I did that after i got the TB on and no luck.
Old Aug 7, 2007 | 09:41 PM
SupermanSS's Avatar
Weird. Did yours come with it ported? Or did you buy it already ported and put it on? I can live with it I guess just wanna know why its doing it ya know.
Old Aug 7, 2007 | 10:05 PM
ErikElvis's Avatar
Ha Im from Townsend. De's small and I dont know where harrington is.
Old Aug 7, 2007 | 11:08 PM
Bo White's Avatar
I and other porters have noticed they do hold a higher than usual idle when comin to a rolling/coasting stop and then drop down once stopped completely. On a relearn, just unplug the IAC and TPS and cut the key to the on position but dont start, a couple of seconds later turn the key off, plug the sensors back up and turn the key back on, a couple of seconds later start the engine. It will now "relearn".
Old Aug 7, 2007 | 11:20 PM
Mike @ New Era's Avatar
Another thing I have noticed , if the car is tuned with the throttle body unported with a cam , and then you get it ported and everything is cleaned including around the IAC area , the idle tune could possibly use to be readdressed .
Mike
Old Aug 7, 2007 | 11:25 PM
ErikElvis's Avatar
On my car my TB is not ported and it will still hold 1100-1200 rpms while coming to a stop then go down when I completely stop. My eclipse does it too.
Old Aug 7, 2007 | 11:59 PM
BLK02TA's Avatar
My s10 did that stock and so does my T/A sometimes. It's just something weird I think. Now if it was any higher or not dropping then I could see an issue.
Old Aug 8, 2007 | 12:19 AM
RevGTO's Avatar
Pontiacerator
The relearn procedure should help; if not, tuning your Desired Airflow tables lower should cure it. Worked for me.
Old Aug 8, 2007 | 07:49 AM
SupermanSS's Avatar
Thanks for the responses im going to do this at lunch and see how it reacts to the re-learn. Erik if your looking to get yours ported/polished Bo is the f'in man!
Old Aug 8, 2007 | 08:01 AM
LastHawk's Avatar
Non-ported TB here as well. Occasionally, I will see the RPMs hang around 12-1500. The situation usually resolves on its own. Probabaly happens once or two every few months. I figured it was the throttle cable stickin..
Old Aug 8, 2007 | 12:32 PM
ErikElvis's Avatar
I think I will be in touch with him very soon.
Old Aug 9, 2007 | 02:00 AM
ShortChevy's Avatar
Mine did this also, I pluged the little whole in the blade with epoxy in case i needed to redrill it and clean it out but it fixed it so I just kept it. I figured it was just getting to much air then what it was designed for, but what do I know other then it fixed it.
Old Aug 9, 2007 | 08:51 AM
SupermanSS's Avatar
Hmmm. might have to try this.
Old Aug 9, 2007 | 10:15 PM
lgobraves's Avatar
mine does idle higher when coming to a stop and will then usually drop once it stops. Any way to tune this out without lowering my idle when stopped?
Old Aug 10, 2007 | 06:11 PM
1cleanbird's Avatar
I had the exact same problem. There is just alot more air comin in so it will idle higher till your completely stopped. A local guy here "Rhino79" tunes ALL the central AR cars, and when he was tuning mine, he just took the code out that lets a small amount of air in between shifts to make it smooth. Shifts are a bit rough at first but you learn to make em smooth. Now my rpms drop instantly like I have a light weight flywheel or somethin. PM Rhino79 and just ask him the details about what I said.
