alternator
Old Nov 19, 2007 | 08:46 AM
Bluebird5.0's Avatar
Originally Posted by Alt
Aside from that I have the normal voltage regulator issue of pulsing lights.
Isn't the voltage regulator inside the alternator? I had my alternator rebuilt by a local guy back in august and ever since I've been having the problems with my lights pulsing. I thought it was the excitor wire this whole time but I've tried so many connections that should have been perfect and still have the pulsing lights. It has to be the voltage regulator...
Also, I fixed the problem with my headlight and all of the wierd electrical issues. It was the motor gear. It just happened to go out at the same time as I'm trying to fix the pulsing lights.
Old Nov 19, 2007 | 06:22 PM
Alt's Avatar
Alt
You are correct the voltage regulator is located within the the alternator.
Old Nov 20, 2007 | 07:10 PM
BLOWNBLUEZ06's Avatar
If anyone having this problem is located in the Dallas, Tx area, I am willing to donate a little time to help investigate this problem. I have 20 years experience working on cars, and 14 professionally installing electronics in cars. I have seen so many posts on this and am very curious about what the problem is. There would be no charge for my time. Only parts if needed.
Old Nov 20, 2007 | 09:02 PM
SoCal01z28's Avatar
Originally Posted by stevensLS1
if yall follow the wire starting at the connector pin from the alternator and go up about 6'' you will see the wire flare out. thats where the fuse is located at. go down to the auto parts store and pick one up they are a few bucks. forget the technical term.
"fusable link"........
and they usually cause an open but sometimes they only partially burn up and still let some amperage thru causing weird symptoms
Old Nov 21, 2007 | 12:18 AM
country_3030's Avatar
I am pretty sure he is referring to a fusible link in the wire. This is a common problem on some cars. The link will get hot but not hot enough to burn into, when there is a large current demand on the alternator. You will find this further explained in a lot of car audio forums.
