header install questions PLEASE help me out
My next question is how in the world do i get those 2 back plug wires off the passenger side? I just cant seem to get any room to grab them.
My next problem is i ran into came from the AIR system. Igot everything off except for the thing behind the drivers side head. I could not find a bolt anywhere to take it off. I was also trying to see the vaccum line that needs to be pluged from it. Heres a pic of the piece i'm talking about hopefully some can help me find out how to get this off and point out to me where the line is that needs to be plugged.
I know i didn't get to far on the install but hopefully some of you guys can help me figure this out. PLEASE. Thanks for any help in advance.
The spark plugs on the passenger side suck. You will probably be bleeding when your done.
, anyways, you just gota stick your arm back there and get them out. I did mine without to much problem, if you have big hands/forearms, maybe try to get a friend to get back there for you....For the air pump to come out here is a how to with pics from ls1tech.
https://ls1tech.com/forums/showthrea...02#post7566902
Good luck, Its a pain, but when your done you will be so happy.
Chris
Thanks again guys
After you do that you can either cap that tube that you circled or you can remove the hose and the electrical connector. After that there will be one tube that is not connected to anything. That will then connect to the back of the intake manifold. You have to cap that or youll have a vacuum leak. Hope this helps.
