What tool are you using to torque down your intake manifold?
Old Aug 20, 2007 | 11:26 AM
99DWPTA's Avatar
Default What tool are you using to torque down your intake manifold?
installing a fast 90. comes with allen head bolts. i know i can go get a allen head socket. but what size torque wrench fits back in there?
1/2 3/8 1/4???
i went to local parts store they only had a 3/8 drive torque wrench but the lowest setting was like 140 inch pounds.
Old Aug 20, 2007 | 12:55 PM
TheLS1Kid's Avatar
Sears has an in/lbs torque wrench that will work.
It is a 3/8 drive.
Old Aug 20, 2007 | 01:17 PM
MrDude_1's Avatar
to be honest, its not a torque-critical fastener...... so most of us just use a quarter drive ratchet... or in your case, an allen key.
its only holding an O-ring seal..
Old Aug 20, 2007 | 01:37 PM
Soul TKR's Avatar
man... i overtightened a bolt on my intake manifold a couple years back... can't remember which one... think it was on the actual intake area... damn thing stripped the little metal attachment that's jammed into the manifold from the factory... fixed it with some JB weld otherwise I would have had to pick up a whole new manifold for something so stupid as an overtightened bolt...
Old Aug 20, 2007 | 02:15 PM
BLK02TA's Avatar
Ditto.
Old Aug 20, 2007 | 02:21 PM
bczee's Avatar
in/lbs Torque wrench.. I would always recommend the uses of the correct tool.
Old Aug 20, 2007 | 02:31 PM
TheLS1Kid's Avatar
Agreed.
Its stupid to have to redo the work because you didn't use the correct tool and messed something up(cracked intake, sealing problem, etc.).
Always remember to use loctite on the intake and TB bolts also.
Old Aug 20, 2007 | 02:35 PM
Phoenix 5.7's Avatar
do the tightening in 2 stages for proper seating. think the "proper" torque specs are 11 and 22ftlbs. i never torque my with a wrench, but always do stages
Old Aug 20, 2007 | 02:39 PM
TheLS1Kid's Avatar
The correct tq specs are first pass at 45in/lbs and second pass at 89in/lbs.
Old Aug 21, 2007 | 09:40 AM
radkon's Avatar
+1 on the 3/8 in drive Craftsman with an allen wrench socket (I think 5mm, I had to go out and search the stores for that one!).
Use the correct sequence and torque specs or you can end up with either an intake leak which will cause some strange issues and take forever to find or snapping a bolt off in the head. (happened to a buddy of mine with the stock intake mani and bolts) took several hours to fix.
Old Aug 21, 2007 | 02:52 PM
TheLS1Kid's Avatar
Definitely.
Autozone has a very nice allen socket kit for like $12. It will come in handy.
Old Aug 21, 2007 | 03:42 PM
99blancoSS's Avatar
snap-on 3/8 drive torque wrench and allen socket
