LS6 Intake vs. LS1 Intake
Old Aug 26, 2007 | 09:33 AM
corvet786c's Avatar
Default LS6 Intake vs. LS1 Intake
I cut the small metal piece on the egr from the LS1 intake. Do I still need an LS6 intake with the cam. Or can I keep the LS1 intake. I know the LS6 intake has better plentium volume. There is no blockage now on my EGR. Thanks for input.
Old Aug 26, 2007 | 10:39 AM
its turbo time's Avatar
check out this dyno sheet http://www.ls1howto.com/howto/geniii...ph-1-15-01.jpg
I found it here:
http://www.ls1howto.com/index.php?article=5
he gained 24 rwhp and 14 ftlbs. going from ls1 intake to a ls6 intake on a cam car, do it and don't look back
Old Aug 26, 2007 | 11:07 AM
corvet786c's Avatar
Alright Thanks Bro.
Old Aug 26, 2007 | 11:12 AM
corvet786c's Avatar
Also what all do I have to change out on a 2000 M6 car. Can i use the LS1 collant pipe fittings or do I have to buy the LS6 style.
Old Aug 26, 2007 | 11:13 AM
Evans752's Avatar
SLP sells a LS6 Intake that comes with EGR provisional. I had on and there nice but if you have cam and things take it with a regular LS6 intake and get the EGR deleted out of the computer.
Old Aug 26, 2007 | 11:31 AM
corvet786c's Avatar
What all do I need to do the swap. Block off plates and what else. Can I get away without the coolant pipe?
Old Aug 26, 2007 | 02:26 PM
RevGTO's Avatar
Pontiacerator
You can chip or grind off the ribs on the bottom of the LS6 intake over where the coolant pipes are. Lots of us have done it and it works fine. Easy and best of all, FREE.
Old Aug 26, 2007 | 02:33 PM
LTLRDSS's Avatar
the ls6 intake from speed inc comes with the ls6 style steam pipes
Old Sep 28, 2007 | 12:44 PM
green28's Avatar
So I can just take the ribs off where the stock coolant pipes run. That would mean I wouldn't have to remove any pipes or block anything off. Do the foam pieces on the LS6 stay on if you use this method?
Old Sep 28, 2007 | 12:53 PM
RedRallyeZ's Avatar
little off topic, but ive never seen the bottom of the FAST, does this method work there too?
Old Sep 28, 2007 | 01:26 PM
tripps's Avatar
I would by the ls6 intake. its not that expensive and you can pick up pretty good power, depending on how deep your setup is. Thats my next mod.
Old Sep 28, 2007 | 02:10 PM
Detoxx03's Avatar
get the ls6 bro
Old Sep 28, 2007 | 02:13 PM
95 Z28's Avatar
Definitely worth it. I got mine off here for 325 shipped and it was worth every penny. Noticeable difference.
