Best exhuast Connectors
Old Sep 3, 2007 | 04:44 PM
lgobraves's Avatar
Default Best exhaust Connectors
I am going to make a custom y-pipe for my xs headers. I am going to use a flowmaster merge going to a 4" cutout then back down to a 3" pipe to connect to the catback.
What is going to be my best bet for connecting the header to the y-pipe. I currently have band clamps and I have tried everything to get them to seal up well to no avail.
I was thinking these were the options
1. V-band clamps
2. Flowmaster Ball Flange
3. 3 Bolt Flange
Any comments on which one would work the best or other ideas that are not up there? I am not going to weld the header to the y-pipe at any cost.
Old Sep 4, 2007 | 12:16 AM
lgobraves's Avatar
ttt..
Old Sep 4, 2007 | 08:41 PM
01 Red WS6's Avatar
I have 3 bolt flanges... I used band clamps before. Both have worked just fine for me. I never had exhaust leaks with either. The flanges are easier to take apart though.
Old Sep 4, 2007 | 09:05 PM
simple's Avatar
stainless band clamps with alot of copper RTV. there are a few different styles too choose from.
have the y-pipe slip over the collector, get some slip fit 2 bolt band clamps and copper rtv all the connections. i know of a good website that sells high quality clamps for about half the price of anywhere else.
Old Sep 6, 2007 | 09:58 PM
01 Red WS6's Avatar
I never used copper RTV with my band clamps. I do use the Copper RTV for my 3 bolt flanges though. It seals up really well
Old Sep 6, 2007 | 10:00 PM
lastcall190's Avatar
V-band. Pricey, but they hold like hell and I never had a SINGLE leak on my old car. What I would do (and hope to at some point), is V-band the headers to the Y, then weld the whole Y, then v-band the Y to the intermediate.
-J
Old Sep 6, 2007 | 10:03 PM
Full-Force's Avatar
The ball flange is by far the best out of those. It is a OEM quality design.
Old Sep 6, 2007 | 10:35 PM
lgobraves's Avatar
that was my orginal thought...hear of very few people running them
Old Sep 7, 2007 | 12:12 AM
Full-Force's Avatar
Thats because its not a direct fit with aftermarket y pipes and they are more expensive.
Old Sep 7, 2007 | 09:46 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I've had decent luck with band clamps, but I'm going to try slotting the pipes a little to see if I can get a little better seal out of them.
Ball flanges, v-band clamps, and 3-bolt flanges are all great too, but require that the fabricator pays attention to what they are doing. A friend of mine installed Kooks headers and a Corsa exhaust on his 2005 Vette, and it was all done with ball flanges and didn't leak.
Old Sep 7, 2007 | 12:20 PM
radz282003's Avatar
Depending on how much room you have before and after the joint. I recommend Walker stainless steel band clamps. They have lap-joint and butt-joint styles and form a really good seal around the pipes without crushing the pipes. Accuseal clamps are really good if you don't plan on removing the exhaust for a while. I've had both and I like each for the qualities I listed above.
Good luck.
Old Sep 7, 2007 | 01:21 PM
lgobraves's Avatar
Well I think I am going to go with the Ball Joints.
The Y-pipe is going to go like this
Collector->Ball Joint->3" piping->Flowmaster Merge->4" Cut out->4" to 3" reducer-> I-pipe
I will post up pictures when it is finished and let yall know how it turns out
