02 sensors!
Old Sep 5, 2007 | 04:56 PM
arrowhead87x's Avatar
Default 02 sensors!
Is there a special way to take out 02 sensors. What kind of wrench can be used to fit around the wiring.
Old Sep 5, 2007 | 05:10 PM
cherryelky305's Avatar
uhh....an open ended wrech? Its big and standard, like 11/16 or something. I forget now, its big though.
Old Sep 5, 2007 | 05:11 PM
jimmyblue's Avatar
Moderator
I have a special purpose deep socket that has a
slot for the wires. But it's really only good after
the sensor has been broken loose, you still need
an open-end wrench (or cut the wires off if the
sensor is to be discarded anyway). I wouldn't buy
the "special socket" again myself, because it's not
tough enough to do the job on its own.
Old Sep 5, 2007 | 05:26 PM
I am just afraid that the open ended wrench will strip easily, where can I get that deep socket to break it loose.
Old Sep 5, 2007 | 07:21 PM
nexvctm2001ss's Avatar
Open ended wrench will not strip the O2 if you use the correct size done this a 100 times
Old Sep 5, 2007 | 07:26 PM
Mudvayne's Avatar
When I took mine out I was short on tools so I just used some vice grips
Old Sep 5, 2007 | 07:37 PM
What size is everyone using 7/8?
Old Sep 5, 2007 | 08:51 PM
TheSilverOne's Avatar
7/8 correct
Old Sep 6, 2007 | 12:52 PM
lspuck's Avatar
7/8 it is....wouldn't hurt to spray a little Blaster or something and let it sit for a minute. Had no trouble getting mine off
Old Sep 6, 2007 | 03:27 PM
okay good to hear, so 18mm wont work?
Old Sep 7, 2007 | 12:30 PM
radkon's Avatar
O2 Sensor sockets work great
Old Sep 7, 2007 | 09:37 PM
hammerhead's Avatar
7/8" wrench, but a couple of mine wouldn't budge even when I put the old cat in a bench vise and pounded the wrench with a hammer. I got some new ones and put some anti-seize on the threads.
Old Sep 7, 2007 | 09:47 PM
txredss's Avatar
If your not going to use the sensor after removing it and its really stuck you can heat the bung with a propane torch , that and a good 7/8 wrench with a light tap with hammer works for me. I would deffinantly not due this with a sensor I was going to reuse!!!!!
Old Sep 8, 2007 | 09:22 AM
rayray979's Avatar
when i changed mine last time didnt feel like looking for size so a crescent wrenh works well also lazyness was a factor then
Old Sep 9, 2007 | 09:38 AM
I bought the o2 sensor socket, it works great.
Old Sep 9, 2007 | 06:46 PM
mterveen's Avatar
Default sometimes
last 02 sensor i took out i used the socket and it flexed enough to strip the threads. ended up using pipe wrench!!!!
