exhaust loss without mandrel bends
Old Sep 17, 2007 | 09:33 AM
mterveen's Avatar
Default exhaust loss without mandrel bends
want to look at getting a 3 inch true dual over axle setup from local exhaust pro shop. how much is lost in efficiency using a regular bending machine versus mandrels? e.g. the 3 inch is "squished" to 2.75 inch on a bend? trying to compare efficiency vs cost. maybe look at a combination of using regular bends for less than 45 degrees and mandrel bends greater than 45?
Old Sep 17, 2007 | 07:05 PM
9t8z28's Avatar
We tested 2 systems with the same muffler, pipes ran in the same locations, but one was compression bend and the other was mandrel bent. We gained 15 horsepower
Old Sep 17, 2007 | 07:08 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
Originally Posted by mterveen
want to look at getting a 3 inch true dual over axel setup from local exhaust pro shop. how much is lost in efficiency using a regular bending machine versus mandrels? e.g. the 3 inch is "squished" to 2.75 inch on a bend? trying to compare efficiency vs cost. maybe look at a combination of using regular bends for less than 45 degrees and mandrel bends greater than 45?
..PLEASE... = AXEL = AXLE ......depends entirely on how many HP you are making...
Old Sep 17, 2007 | 07:15 PM
Fb0dy0nly's Avatar
better off buying some mandrel bent exhaust piping from summit or something and then having them weld it together. You might as well just do a catback that is mandrel bent instead of running non-mandrel duals, especially if you are going FI.
Old Sep 17, 2007 | 11:19 PM
mterveen's Avatar
Default mandrels it is
is summit or jegs mandrel tubing the popular source or someplace else "cheaper"?
Old Sep 18, 2007 | 08:35 AM
Fb0dy0nly's Avatar
your best bet is to call speedinc or another shop familar with running TD setups out the back because I know they do custom setups and they can help you get the parts you need to have one installed. They also carry universal custom kits like this http://www.ls1speed.com/cont.cfm?cid=C0000033 but it dumps at the axle.
Old Sep 18, 2007 | 06:00 PM
9t8z28's Avatar
Try pypesexhaust.com
