Going to track...ned 2turn off asr..for real!
Old Sep 17, 2007 | 09:00 PM
mikenews's Avatar
Default Going to track...need 2turn off asr..for real!
I'm gonna run her at the track, but even with turning switch off on dash it seems to kick back on. Can I disconnect the electrical connector at the cruise unit right above the battery? When I tried it the asr light came on. Will this work?
Old Sep 17, 2007 | 09:22 PM
CAMAROZ28AQUINO's Avatar
is it just the low traction light in the dash or is it actually the ASR button?
Old Sep 18, 2007 | 11:02 AM
mikenews's Avatar
When i turn the switch off on dash it still seems to kick back the throttle while spinning off the line.
Old Sep 18, 2007 | 11:37 AM
jimmyblue's Avatar
Moderator
If you disconnect the gizmo connector it should fault on
startup, give you the ASR OFF light and not try to "help".
