Puzzling problem - please read!
Old Jan 3, 2008 | 03:06 PM
  #321
Tainted's Avatar
ok Thunder Racing said my ls6 conversion for the pcv along with the ls6 coolant lines block offs and the y pipe bump hanger will be here by tuesday so prolly no real updates till tuesdayish. until then ill probably put the header on along with the coil packs and the rest of the exhaust
Old Jan 3, 2008 | 03:57 PM
  #322
bad6as's Avatar
way to stick with it......
Old Jan 3, 2008 | 10:25 PM
  #323
Tainted's Avatar
uh-oh!! Another update! Passenger side header is on, and look what else is finished now...
Old Jan 4, 2008 | 10:45 AM
  #324
ArcticZ28's Avatar
Great.
Check your rear end fluid before it's off the lift.
Old Jan 4, 2008 | 09:18 PM
  #325
TORCHD 02 TA's Avatar
ok i jsut read all 17 pages of this thread. and all eleventy billion of the other thread from a year ago..
All i gotta say is good luck Charlie. Looks like you have a finally touched the learning curve.
I have a 228/232 cam and i am using 7.425 PRs... Now my heads are stock 241s and are not milled, so i have no idea what affect that has with using the 7.3 PRs...
but anyways, good luck i am antisipating the start up video
Old Jan 4, 2008 | 11:18 PM
  #326
Tainted's Avatar
did even more today. Lined up my front bumper better closed the gaps on the fenders, working on finishing up the passenger headlight this weekend and tracking down the hood latching components. Also have all the exhaust tied up and adjusted fairly well. just need to mount my POS spohn d/s loop. Also got the fans in and hooked up, all the water hoses are hooked up as well and the air lid tray is on.
sorry no pics, I'll get them tomorrow
Old Jan 5, 2008 | 05:10 PM
  #327
Tainted's Avatar
boy oh boy did I work my *** off today!
Finished all of the exhaust, its wrapped in heat tape, fully adjusted
oil pan is all bolted up and theres now oil in the car
got the tranny dipstick tube in and the oil tube
did some more body work
serviced the rear end
all connections are hooked up except for the obvious ones (intake coils injectors)
valley cover is off awaiting LS6 PCV
Old Jan 5, 2008 | 05:13 PM
  #328
WS6NIGHTMARE's Avatar
Sweet! You need to go update on FBL.
Old Jan 5, 2008 | 07:42 PM
  #329
Tainted's Avatar
yeaaa I suppose I'll post these on up over there for ya
Old Jan 7, 2008 | 09:42 PM
  #330
Tainted's Avatar
Important announcement!
Tomorrow is the big day (for the 3rd time)!
Everything is hooked up at this point, jsut plugging in my coil packs and putting my spark plug wires on and starting i up. Everyone say a prayer that everyhting goes well, its time for me to get a damn break!
Old Jan 7, 2008 | 10:15 PM
  #331
Reject's Avatar
well lets just hope you put oil in it lol
Old Jan 7, 2008 | 10:16 PM
  #332
Tainted's Avatar
lol yes 5 qts and even put on a fancy K&N filter.
Old Jan 8, 2008 | 12:52 AM
  #333
Demon Of Dreams's Avatar
only 5 and a K&N Filter?
in for breakage
Old Jan 8, 2008 | 10:25 AM
  #334
ArcticZ28's Avatar
Hmmm... you using the K&N truck filter? The "2006" or whatever one?
Old Jan 8, 2008 | 04:09 PM
  #335
if your using K&N oil filter HP 2006, you will need more than 5 qts....
All i can say Charlie is good luck...
I can not wait for the vid
*crosses fingers*
Old Jan 8, 2008 | 05:28 PM
  #336
Reject's Avatar
oh god.
taint if you fkk up the oil change just sell the damn car, we wont laugh out loud in your fac3
Old Jan 8, 2008 | 06:12 PM
  #337
OK good news.....
The car cranked.....and started right up!
The bad news.....
Oil pressure never came up. He let it run for about 10 seconds and then shut it down. Sending unit is hooked up. He did re verify there was oil in the motor. the oil pump is brand new so I dont think its that. He's going to crank it some to see if the system primes up.
Suggestions?
Old Jan 8, 2008 | 06:26 PM
  #338
Originally Posted by WS6NIGHTMARE
OK good news.....
The bad news.....
Suggestions?
put more than 5 quarts in?
Old Jan 8, 2008 | 06:28 PM
  #339
I did think that, and even told him to last night. But right now, thats not going to keep it from getting pressure.
Old Jan 8, 2008 | 06:38 PM
  #340
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
They hold 5.5 quarts with a normal filter. The K&N holds about .25 quarts more oil. It might not be the problem, but it's a bad idea to have it like that. Did you pre oil the filter? Might not be showing pressure because of a dry start.
