Heat Soak..
Couple facts :
1.) So threw traffic and/or at a stop you will begin to see the aluminum intake "heat-soak"
2.) In between runs at a drag strip you can always ice the intake if your not "hot lapping"
I guess you have to weight your options and see whats best for you. I like going to the strip, but streetracing is always going to happen. And if someone pulls up next to me in a cobra after sitting in traffic. I'll be sucking in some hot air. I love the look of the metal intakes, and like the idea of how they can be really cooled down between runs. And if they out-flow a ls6 (since the fast is out of the picture for me) I think im in. Im going to ask a few seasoned veterans to voice there opinion and see what they think.
if heat soak was a myth then turbo chargers would not need intercoolers
most of you are talking about the intake taking in air that is for the most part cooler than the intake, but in the case of most engines especially cars on this board what engine takes air directly from the outside???? none that ive seen, reguardless of ram air most cars are drawing from the engine bay area. here is where i think the point is to be made
if a metal intake heat soaks it will raise the air temp around it i.e. engine bay thus raiseing the temp of the air coming into the engine reguardless of the speed of the air you are still pulling in warmer less dense air which affects performance, how much??? for most of our street cars the affects are marginal at best. then there is something to be said about moving cars circualting the air under the hood reguardless if the air under the hood is warm your sucking warm air.
so if you have a chance to lower under the hood temps it could be worth it.
THanks. That is good info. I'd much rather see the track times than the feelings. Good stuff!
over ls1 manifold:
ls6-15hp/13ftlbs
weiand-15hp/14ftlbs
fast-20hp/17ftlbs
bbk-28hp/20ftlbs
so from that test,bbk out performed the more exotic fast 90 manifold that costs $800 plus, which in my opinion is way to much for an intake. besides the metal manifolds look better and cost less than most composites and from the test work better and should work good for a d/d car.
