X-pipe and H-pipe vs No-pipe
Old Sep 21, 2007 | 01:07 PM
Asmodeus's Avatar
Default X-pipe and H-pipe vs No-pipe
Is there any reason to run an X or H over just 2 pipes off the headers into a muffler then dumped? Seems much more cost efficient to not run an X or H, and I don't see where an X or H would create more of a "suck" when gasses are colliding vs just exiting a 3" pipe with a bullet muffler.. or is it just for sound?
Old Sep 21, 2007 | 01:17 PM
whitetaws6's Avatar
hey man I have found that it makes little difference at all. i have a heads and cam 02 WS6 and i have ran an h and an x pipe, and dynoed both there is hardly any difference at all. When I ran straight pipe off each header and into a muffler then dumped it i lost about 2 lb/ft of torque on the bottom end but gained it back up top. The h and x pipe will quiet it down a lil more that straight through will though.
Old Sep 21, 2007 | 01:48 PM
turbowhistle86's Avatar
I did it because it smooths out the exhaust note, and quiets it down a little bit. You don't have to, but I'm sure there some power gains, its just a matter of how bad 3-5hp is worth to you.
Old Sep 21, 2007 | 03:18 PM
Juicedz28's Avatar
Im in the same situation. I run straight pipe off the header. And posted a thread a few days ago to see if i was losing power without the "scavenging" affect
Old Sep 22, 2007 | 03:13 AM
Asmodeus's Avatar
anyone else?
Old Sep 22, 2007 | 06:53 AM
DSRCAM's Avatar
im running a 3 inch h pipe and she feels mighty good...
Old Sep 22, 2007 | 08:56 AM
'00_Z's Avatar
While crossover pipes will help with the sound and may not gain much peak power, they can help increase power under the curve. This helps create a stronger mid-range. Of course every car will react differently and there are a ton of deciding factors.
Old Sep 22, 2007 | 10:09 PM
chefman's_TA's Avatar
H all the way man..I've had both X-H setups, more tq down low as to x's. deeper, throatier note as well..
Randy
