My car sound likes crap!! Help!!
Ok i have a 98 t/a with long tubes and offroad y-pipe. At first i had the flowmaster kit on the car but wasnt that satisfyed. So last week i ripped it off and went with a dynomax bullet and a dynomax y in the rear where the flowmaster use to be so the pipes still exit the rear. It sounds good and loud reving it and putting around keeping the revs under 2200 or so. But when i get on the throttle it makes a bad popping sound, like a typical pickup with straight pipes. It sounds really really bad. I need help, please!!!
You are experiencing rasp. Some mufflers have more rasp than others (slp lm) and having an off road y pipe may be giving you more rasp as well.
Usually people will add cats to their y pipe or weld a bullet muffler in the I pipe to help reduce some of the rasp.
Originally Posted by orangeapeel
Bullets are main causes of the rasp. I would look into a chambered muffler like a magnaflow or something to that effect.
I agree, pretty much any "bullet" is going to have rasp. Try a Borla or Magnaflow or maybe even a long Powerstick.
I have a small amount of rasp in my setup, its a Magnaflow catback. But it sounds nothing like those "big redneck trucks" that you describe. And i'm here at A&M..those trucks are everywhere.
Bad poping sound when you get on it? My setup is different than yours but i have dual bullets and the only time it pops on me is when i am in gear slowing down. What size bullets did you purchase?
A chambered muffler will solve this or cats will get rid of the rasp
I have dynomax 24222, its 3in inlet and outlet and 12in long. Its placed down the center of the car, in between the y pipe and the over the axle tube.
I was looking in one of my jegs and saw a Moroso bullet simular to my dynomax. Anyone ever used one of these? They are a spiral flow muffler instead of a perforated design like my dynomax. Would one of theses maybe solve my problem or would it still have that really loud rasp. Which muffler would use recommend?? I still want my exhaust to exit out the rear, and i would like to reuse my 3in tail pipes and over axle pipe.
