LS6 Intake crossover pipe????
Old Oct 9, 2007 | 09:04 PM
nhra_crazy's Avatar
Default LS6 Intake crossover pipe????
Am I going to need it to do my swap onto my Ls1?? What issues am I going to have or can I just install the intake?? Thanks for any info
Old Oct 9, 2007 | 09:10 PM
The Postman's Avatar
hey man i just did mine today, i used a crossover on the front tube and two plugs for the back, make sure when u take the old intake off to take the tape off the knock sensor wires and remove the green clips, they won't fit under the new intake, and watch out for the oil sending unit!!!..I broke mine and it cost me 40 bucks! It does take awile since if its ur first time but its all about the learning experience
Old Oct 9, 2007 | 09:21 PM
Frans96SS's Avatar
yes you will need the ls6 coolant pipes.... and like maroboy said take the green clips off.....nothing too difficult...
Old Oct 10, 2007 | 07:52 AM
nhra_crazy's Avatar
Anyone got what I need laying around???
Old Oct 10, 2007 | 08:05 AM
green28's Avatar
I'm in the same boat as you. I decided to spend the money and buy the LS6 pipes and the block offs. There is another option which is grinding off the ribs of the LS6 intake and using the LS1 coolant pipes, but I'd feel more comfortable using the pipes that were intended for the LS6 intake. And if I ever sell the LS6 then it will still be in good shape and not all hacked up.
Old Oct 10, 2007 | 04:48 PM
Brian2006's Avatar
You can just grind the ribs down on the bottom of the ls6 to make the coolant pipe fit
Old Oct 10, 2007 | 09:58 PM
nhra_crazy's Avatar
Anyone got a gm part number on this. I might just get it from my dealer...
Old Oct 11, 2007 | 04:37 AM
Cole Train's Avatar
texas-speed.com has them for like $50 shipped. check 'em out. Or Ebay has the same kit's all the time.~Cole~
Old Oct 11, 2007 | 05:27 AM
Thule's Avatar
byunspeed.. $36
Old Oct 11, 2007 | 08:02 AM
nhra_crazy's Avatar
Thanks guys!!
Old Oct 11, 2007 | 09:36 AM
green28's Avatar
Originally Posted by Thule
byunspeed.. $36
Nice find, just put my order in for one.
Old Oct 11, 2007 | 11:00 AM
Galen's Avatar
Third option is to cut your LS1 pipes and braze them closed. I had lost my front LS6 pipe and did this with no problems.
When pulling your LS1 intake, reach your hand back to the brake hose and be sure you lift the intake over the oil pressure sensor unless you really want to try to find another while your car is apart.
Galen
Old Oct 11, 2007 | 11:22 AM
Ryan33187's Avatar
I took a wire sander and sanded down the ribs on my ls6 intake and then took a flat hammer and a peice of wood and hammered down the parts of the coolant pipe that held the intake a up a bit my ls6 intake now sits real snug! Now the hammering part no I didn't kill the pipe I just made it more oval rather then circular. Works great
Old Oct 11, 2007 | 11:30 AM
Thule's Avatar
yeah byunspeed always has good price i.m.o i've spent some thousunds there
Old Oct 11, 2007 | 11:31 AM
Thule's Avatar
i btw bougth couple of those sets, they are fine
