BG Ram Air mod.................
Old Jun 8, 2003 | 09:49 PM
Quickin's Avatar
Default BG Ram Air mod.................
Is it a good one for my motor?
I was told to remove both baffles and it'll be good for .15 in the 1/4 and about 15 HP. This is the ET improvemnt on my friends bone stock 2000 WS6, everything else was factory stock.
Old Jun 9, 2003 | 12:12 AM
Z-Rated's Avatar
Default Re: BG Ram Air mod.................
LOL as if your motor is "special"
I have heard that it works, and ive also heard that it doesnt do crap. Either way it is probally worth doing. Just be sure you can plug it, incase you get caught out in the rain.
Old Jun 9, 2003 | 01:14 AM
Quickin's Avatar
Haha, I said it that way because I've been told it's a stock cube, non H/C motor type of mod. Basically for factory stock cars. I don't see why it wouldn't work for a big motor just the same. Thats why I asked.
And my motor is special, to me
Old Jun 9, 2003 | 01:32 AM
Gev's Avatar
Gev
Why do you think your motor is special? All F-Bodies come with 436ci Super Strokers from the factory...
And about the mod, I did a similar one with my Ultra-Z Hood and with a ported TB my 1/4 dropped .3.
Old Jun 9, 2003 | 01:35 AM
DONAIMIAN's Avatar
The only down side to it is the fact that you have to block it off in the rain.
Old Jun 9, 2003 | 03:12 AM
Quickin's Avatar
They give you a rain guard with it that pops in in about 10 seconds.
Old Jun 9, 2003 | 10:43 AM
Z-Rated's Avatar
Sweet then go for it. let us know how it works on a "special" motor :p
Old Jun 9, 2003 | 05:57 PM
Quickin's Avatar
I'll dyno it with and without to see if it's worth a f%$^.
Old Jun 9, 2003 | 11:39 PM
phaphaphooey's Avatar
alot of people on ls1.com swear by it. it really helps gas mileage as well as shaving .1-.2 off of your quarter mile. plus if you have an oil based filter, most dont even bother with the rain blocker.
Old Jun 10, 2003 | 05:15 PM
pimpmaro's Avatar
hey, wait a damn minute... I didn't get the 436 super stroker!! I feel cheated...
Old Jun 10, 2003 | 05:30 PM
Slowhawk's Avatar
LS1Tech Sponsor
Won't be worth anything on the dyno,but I'm sure it will help on the road
Old Jun 11, 2003 | 03:17 PM
mpmWS6's Avatar
I have had the mod for about 6 month now and love it, other than having to use the rain blocker when it pours. I do not even worry about putting the rain blocker in if it is only sprinkling, but if it is a pretty good rain you need it. Because, if you dont "you will" throw a code that will go away eventually. It does help out tons on the road and in the 1/4 mile. I removed the baffles and you can notice a big difference with the mod and the baffles removed.
IMO it is a good investment to make your WS-6 a TRUE Ram Air.
Make sure you keep the foam seal well lubricated, if not you will tear the hell out of it.
Old Jun 12, 2003 | 08:20 PM
Jammer's Avatar
Very unlikely it would increase a dyno number unless your tuner dynos the car hot wiith the hood closed normally (and if you have, say, stainless header). The cooler air in that situation may pony up a tiny amount. This mod can only be judged at the track and open road. I'd bet at speeds over 100 mph it starts to make a more bigger difference that is hard to "feel", but definately there. Mine is still in the box...3 months later...as it Brets TB...aahhhh..someone just come do it for me...I'm tired.
Old Jun 12, 2003 | 08:57 PM
Dave Carney's Avatar
I took mine off tonight (the seal and it's holder), I think I'll go faster...testing it sunday.
Old Jun 14, 2003 | 09:15 PM
BigPlanTransAm's Avatar
phaphaphoey: why would an oil based filter keep out rain?
Old Jun 16, 2003 | 11:43 AM
I took off the seal and it's holder, gained 1.5mph. If you run with the seal, don't race with the nostril grills in!, you need every bit of that opening you can get. Brian recommends taking the grills out for racing too, I think. Look at the open area of your lower air box section, now calculate the open area of the nostril grill holes...considerable difference. On a WS6 box, you come up about 50% short, on a stock box about 25%.
Your results may vary.
