what to do with the pcv system
Old Oct 14, 2007 | 02:35 PM
dutinsss's Avatar
Default what to do with the pcv system
my '02 SS has about 68000 miles on it and i want to sea foam it. i figure before i do that, i might as well replace the pcv system. i've heard a few ways to go about doing this but what is the best thing to do to it?
Old Oct 14, 2007 | 08:08 PM
INMY01TA's Avatar
Use a catch can if your getting oil in the intake.
Old Oct 14, 2007 | 09:32 PM
dutinsss's Avatar
is there a way that doesnt use the catch can?
Old Oct 15, 2007 | 07:19 AM
blackcat's Avatar
ttt....
Old Oct 15, 2007 | 09:46 AM
chuckyt1's Avatar
Some guys use breathers instead of a PCV system and some use a crankcase evac systeml like this one,
http://www.jegs.com/webapp/wcs/store...10002_21252_-1
Old Oct 15, 2007 | 09:53 AM
dutinsss's Avatar
is the part in the link good for street use. it says its primarily for drag racing use and my cars a daily driver. so are there any negative affects to it?
Old Oct 15, 2007 | 10:07 AM
chuckyt1's Avatar
It's not emissions friendly, I think that's why the "DR use only", but I haven't used it and don't know too much about it. I have heard that it works quite well though. There's an old thread in here somewhere about it. Pretty sure Orange uses it.
Old Oct 15, 2007 | 10:15 AM
dutinsss's Avatar
well emissions dont matter where i'm from so as long as it works and gets rid of all those hoses, i'm all for it. but i'll search for the thread you were talking about.
Old Oct 15, 2007 | 10:31 AM
dutinsss's Avatar
well i think i'm going to go with the catch can i found from thunder racing. now does this replace all the pcv hoses and valves and whatnot with the can and the two short hoses? and is there any maintenance involved with this setup?
Old Oct 15, 2007 | 10:49 AM
chuckyt1's Avatar
Here's a pic of my Thunder can. Still have the PCV valve, in the valve cover. The only maintenance required is emptying the can once in a while.
http://www.fquick.com/garages/viewga...ewimg&id=65191
Old Oct 15, 2007 | 10:52 AM
dutinsss's Avatar
thanks for the pictures, i think thats what i'll go with. was it a pretty simple, straight forward instal? was the tube that leads from the can to the back of the motor very hard to get hooked up?
Old Oct 15, 2007 | 11:05 AM
chuckyt1's Avatar
Yep, takes about ten minutes...
Old Oct 15, 2007 | 11:08 AM
dutinsss's Avatar
alright, cool. i was thinking that tube from the back of the motor to the can would be a pain.
Old Oct 15, 2007 | 12:45 PM
xBROKEx's Avatar
id think just using a breather would be the easiest since there is no chance for it to get back into the intake
Old Oct 15, 2007 | 02:34 PM
Yahelou's Avatar
well, from what i read about the breathers, the problem with it is it makes the car smell like oil and that the oil gets on the bottom of the hood. besides the catch can is nice and easy, u can go to home depot or lowes and make one urself.
Old Oct 16, 2007 | 07:46 AM
blackcat's Avatar
so chucky. What intake do you have on your ls1? Is that the LS2?
Old Oct 16, 2007 | 11:05 AM
chuckyt1's Avatar
Fast 78 ported out to an 85mm with a ProProducts 85mm TB.
Old Oct 16, 2007 | 11:55 AM
Ping King's Avatar
many of those pan evac systems require absolutely no backpressure to be able to properly scavenge the crank case vapors. Im not sure really whether or not they really work on street car type setups.
Old Oct 16, 2007 | 04:06 PM
DMONEY06's Avatar
i say stick with the stock pcv! from personal experience it can be a PITA at some point..
NED
Old Oct 16, 2007 | 04:16 PM
dutinsss's Avatar
well i just ordered the thunder racing pcv catch can last night, so hopefully that'll do the trick. thanks for the replies
