1998 Z-28 with no cats?
Old Oct 26, 2007 | 07:11 AM
pimpingreen13's Avatar
Default 1998 Z-28 with no cats?
Im looking into buying a 98 Z-28 but the car has no cats. Does this affect the performance of these cars at all? I know with some cars it sets your ecu into limp mode, but not sure about these. Any help would be apprecaited. The guy says it has a service engine light or whatever, but that it can be deleted.
Old Oct 26, 2007 | 12:37 PM
John02Hawk's Avatar
Does it hurt the car? No. Will you pass emissions tests? No. Could there be more engine codes and this guy just isn't telling you and using this as a cover up? Yes.
Old Oct 26, 2007 | 12:41 PM
Joey@Tick's Avatar
LS1TECH Sponsor
Most of the cars that come through our shop have previously had the cats removed. It does not send the computer into any kind of limp mode, but it will throw a check engine light and the car won't be able to pass the computer emissions test with the light on. Computer tuning can fix that for you.
I'd have the computer codes checked before you purchase the car - as John02Hawk mentioned, there could be other (serious) problems with the vehicle.
Old Oct 27, 2007 | 09:13 AM
To scan these cars for codes, you need a code reader correct?
Old Oct 27, 2007 | 10:18 AM
3rdgentug's Avatar
you can take it to like autozone, they will do it for free
Old Oct 27, 2007 | 11:34 AM
code4's Avatar
How did he delete the cats? Ask him if it is an aftermarket Y pipe or if the car has long tube headers.
Old Oct 27, 2007 | 12:44 PM
The car has long tube headers. Why?? Sorry for all the questons, this will be the first american can I have ever looked into. I used to be more into imports, but want a RWD.
Old Oct 27, 2007 | 01:14 PM
CETA_TransAm's Avatar
my friend gutted his t/a's cats but he put 02 sims on the back to it sounds better and is a bit faster
Old Oct 27, 2007 | 10:57 PM
ZTwentyAteU's Avatar
like stated above just check the codes. My TA had a bad AIR pump and the check engine bulb was taken out when I bought it. I didnt care because I transferred my tags(no emissions on a transfer). I just deleted AIR on HP tuners so no worries here, but just double check!
Old Oct 27, 2007 | 11:51 PM
RedRallyeZ's Avatar
why like what is the benefit?
in a nutshell, they smooth the transition of the exhaust gases to let them converge in a less violent way=more hp
