Help!!!!!!!
Old Jun 16, 2003 | 03:13 PM
TMar99Z28's Avatar
Default Help!!!!!!!
Guys I'm in the middle of installing my Hooker LT's, I have the driver's side on, but i can't to the very back bolt on the passenger side manifold, I've tried every thing I can think of and I'm completely stumped, any help would be great. Thanks in advance.
Old Jun 16, 2003 | 03:17 PM
TMar99Z28's Avatar
Default Re: Help!!!!!!!
TTT
Old Jun 16, 2003 | 03:31 PM
Chris99WS6PWTMET's Avatar
Have you tried it from the bottom? If so, then make sure you have the gasket facing the right way.
Old Jun 16, 2003 | 03:40 PM
TMar99Z28's Avatar
I tried it from the bottom and was having a hell of a time keeping the ratchet/wrench or whatever i was trying at the time on there, plus my hands don't fit.
Old Jun 16, 2003 | 03:53 PM
CAT3's Avatar
Restricted User
I had to have a friend hold the header from the bottom, wiggled a bit and the bolt popped right in. I am using Stage 8 bolts, but, use a 1/4" ratchet and socket to get it nearly tight, then an open/box end wrench combo, minute turns and patience. Good-luck.
Old Jun 16, 2003 | 04:02 PM
TMar99Z28's Avatar
I finally broke it loose from underneath, any tips for when i got to put the passenger side header on?
Old Jun 17, 2003 | 03:27 AM
malibu350's Avatar
take the starter off....wit will go a lot smoother then...and you may have to tilt the motor a bit with a pry bar...
Old Jun 17, 2003 | 07:07 AM
Viper's Avatar
I put a pillow on the battery so I could put both knees on it for support. Then I can get to that last bolt from the top with a 1/4" drive, small small turns.
 Michael S. Palmer
