High idle...can anyone help???
Old Nov 11, 2007 | 10:13 AM
second_2_none's Avatar
Question High idle...can anyone help???
i just had these mods on my car, p&p MAF and t/b, ls6 intake, long tubes and o/r y pipe, and catback. it made a huge difference but now my car is idling really high and i have to ride my brakes a lot around town just to stay in the speed limit cause my idle. when my car is in drive and im on the brake it idles at 1k, but in park or neutral its like 1500. can anybody help?
Old Nov 11, 2007 | 11:11 AM
shoemike's Avatar
what are you using to tune?
Old Nov 11, 2007 | 11:30 AM
Rhino79's Avatar
Sounds like the TB was ported too much around the blade area, letting too much air in when the throttle is closed.
Old Nov 11, 2007 | 12:23 PM
GMmexican's Avatar
At first when I got my throttle body ported my idle would stay high......but after a few weeks it went back to normal, the computer just has to re-learn how to idle again
Old Nov 11, 2007 | 02:17 PM
jag42420's Avatar
Agreed. If your TB was overported around the blade, your idle will stay high until you get another TB.
Drive around. Get at least 100 miles, preferably about 200 miles on it so the PCM can relearn everything. With the MAF porting and the LS6 intake, I hope you forgot to mention your tune, because you could definitely use one.
Old Nov 11, 2007 | 03:07 PM
BlueStreak362's Avatar
is the check engine light on? if it is its likely a IAC code, might be over extending itself to try and correct the high idle.
Old Nov 11, 2007 | 05:12 PM
BadgeZ28's Avatar
There is also a manual adjustment screw on the throttle, but you need to zero the throttle position after adjustment. You set the adjustment. Then unplug the throttle postion sensor and turn the key to on for a short period-don't start the motor. Then off and reinstall the TPS sensor wiring. Turn it back to on and then off.
Old Nov 11, 2007 | 06:23 PM
ok those are all good posibilities, the guy who did it all said the same thing about the computer having to relearn everything and to give it some time. if it dont ill check the blade on the throttle body and try the adjusting screw. but i didnt have it tuned, i heard that wouldnt make much of a difference unless i have a cam.
Old Dec 21, 2007 | 03:18 PM
Schnell's Avatar
2nd2none, what was your outcome with this? I'm having a high idle problem after replacing the battery and it's probably been 200+ miles and it still is too high.
Old Dec 21, 2007 | 03:37 PM
Medic/Z28's Avatar
I just did my own porting of the TB and found that I needed to change out the IAC valve. Its a $100. It's still learning itself as it still idles high at times on starts. Another thing make sure all screws are on well and snug. That seems to be a hugh factor.
Old Dec 21, 2007 | 03:47 PM
98TADRIVER's Avatar
Is your SES light on? if you dont have a code reader, go to autozone or advance auto, they scan for free. in the meantime, if you didnt have your stock tb ported, put your stock TB back on and see if that corrects your problem.
Old Dec 21, 2007 | 03:50 PM
TheLS1Kid's Avatar
Maybe you have a vacuum leak somewhere around the intake.
Was it torqued down enough?
Old Dec 29, 2007 | 12:55 PM
pddye's Avatar
schnell replied to your pm.
