The Importance of Intakes: Real World
Old Nov 16, 2007 | 10:35 AM
Thumpin305's Avatar
Default The Importance of Intakes: Real World
I recently bought an Interceptor gauge for my 2002 3.8 Camaro. My Camaro has a K&N filter, SLP intake, smooth air lid, and !AirSilencer. A friend of mine came over who has a stock Camaro except for his K&N, so I decided to hook the gauge up to his car to get some readings.
Between our two cars, I got some real world numbers that explain just how helpful the SLP intake is.
Air Temperature
At the time of testing, it was 63 degrees outside. While driving my car AND parked, the air temperature (which is read by the AIT sensor) read a constant 63 degrees.
The stock Camaro would read between 80-85 degrees while driving and 90-92 degrees parked.
The only reason for the difference in temperatures between the two cars is the SLP intake. While I am getting cool air from in front of the radiator, my friend's car is sucking up hot air from under the hood
Air Flow
The Interceptor gauge also measures how much air, in lbs/min, are going through the maf sensor.
At idle, my engine sucks in beteen .60 to .65 lbs of air per minute.
My friends Camaro, at best, would use .52 lbs/min.
This proves that air intake modifications really help. The difference between the above two numbers may not look like much, but on the highway, those numbers increase drastically. I forgot to write down his data, but at WOT my car uses 20 lbs/min of air.
Old Nov 16, 2007 | 11:54 AM
FireSilverLullaby's Avatar
yeah that does help. im getting one of those gauges soon, cant wait.
Old Nov 16, 2007 | 01:06 PM
Brads LS1 02Z's Avatar
if you get a chance to re-do his on the highway at wot i would like to see his compaired to yours
Old Nov 16, 2007 | 04:04 PM
Thumpin305's Avatar
I meant to do that, but I didn't write it down and I've completely forgotten what the numbers where. It may be a while before I can test his car again, but when I do I will post them up.
Old Nov 19, 2007 | 12:51 AM
Thumpin305's Avatar
I figured more people would be interested in this.
Old Nov 19, 2007 | 01:21 AM
Shockwave179's Avatar
It's decently interesting. I'd defin be curious to see a WOT run too.
Authrom's Avatar
It is interesting but, I don't think anyone denys the usefulness of intake systems. Its one of the first things people usually do....but just throwing more air into the system alone isn't going to do much so I guess since its part of a system it doesn't get the "glory" it diserves.
Old Nov 19, 2007 | 11:18 AM
Thumpin305's Avatar
True. I've just never seen anybody post numbers except for 1/4 mile times. I'll try and get some WOT runs after Thanksgiving.
