$100 for bolts?
Old Nov 19, 2007 | 06:03 PM
99_SS_LS1's Avatar
Default $100 for bolts?
I am having a hard time justifying spending $100 on the ARP header bolts. Is this necessary or a waste of money?
Old Nov 19, 2007 | 06:22 PM
Tainted's Avatar
grade 8 bolts are 70$ cheaper and jsut as good. Hell most people re-use their stock bolts with a little anti-seize
*woops no loc-tite for header bolts
Old Nov 19, 2007 | 06:28 PM
BLK02TA's Avatar
I used anti seize on my header bolts.
Old Nov 19, 2007 | 06:30 PM
TheSilverOne's Avatar
loctite? no
anti seize? yes
Old Nov 19, 2007 | 06:55 PM
stevied916's Avatar
I reused the stock with antisieze...dont use loctite
Old Nov 19, 2007 | 06:57 PM
Tainted's Avatar
woooops my bad, antiseize, had a brain fart moment there.
Old Nov 19, 2007 | 07:49 PM
95 Z28's Avatar
I originally planned on using the new ones that came with my Pacesetters, but when I went to tighten them down, they got kind of mushy on me, so I threw the stockers back on. I'm not cheap by any means, but $100 for some ******' bolts?!?! No way.
Old Nov 19, 2007 | 09:45 PM
99_SS_LS1's Avatar
That's what I was thinkin... how about new gaskets? It's a 2000 w/21k miles
Appreciate the help
 Michael S. Palmer
Old Nov 19, 2007 | 09:47 PM
Tainted's Avatar
you can re-use your stock gaskets as lnog as they look good, fi youre unsure, buy STOCK gm gaskets
Old Nov 19, 2007 | 10:06 PM
g-ryde1's Avatar
i bought the header studs no complaints whatsoever for my pacesetters with MLS gaskets
Old Nov 19, 2007 | 10:40 PM
simple's Avatar
you've got ~$350 headers and ~$100 ARP header studs?
Old Nov 19, 2007 | 10:41 PM
bigdsz's Avatar
Get the Stage 8 locking bolts, they are stainless, nice product, sponsors sell them for like $40.
Old Nov 19, 2007 | 10:45 PM
simple's Avatar
since no one could answer this in another thread where Stage 8's were recommended... how do you use Stage 8 locking header bolts on an LS1?
maybe i'll get an answer in this one.
Old Nov 19, 2007 | 11:17 PM
Jeff@TotalPerformanceEng's Avatar
Its crazy.. I've had my stock bolts on and of 30 times. I've never had an issue. If you want, go to your local bolt store and buy some hardened bolts. You'll spend 20 bucks total.
They are torqued to a max of 18lbft. Its virtually impossible to crossthread them unless you over tighten them.
Old Nov 19, 2007 | 11:19 PM
You dont even need the locking style. All you need is standard grade 8 "metric" bolts. ANY nut/bolt store is gonna have them.
Old Nov 19, 2007 | 11:23 PM
simple's Avatar
yes, i know. i use the cheap bolts that came with my headers. nothing fancy and they get the job done! and i agree about going to a hardware store and getting bolts there. you can also get studs there
i just want an answer on how to use the locking bolts on an LS1 when the bolt holes are smack inbetween the primaries.
Old Nov 20, 2007 | 10:47 AM
bigdsz's Avatar
There is a SS flange that slips into a groove on the bolt itself. The flange itself stops the bolt from backing out by being stoppped by the primay tube. I've had the bolts for like five years without an exhaust lead. Many bolts start to work their way out because of the constant expansion and contraction of the heads and headers.
Old Nov 20, 2007 | 11:01 AM
regorih383's Avatar
im using stock once and im making over 500rwhp
Old Nov 20, 2007 | 11:02 AM
socmguy's Avatar
Restricted User
Use the stockers, ARPs are good too. I'm working on a car right now with a broken header bolt. They were those 40 dollar locking pieces of ****.
Old Nov 20, 2007 | 11:08 AM
RedRallyeZ's Avatar
i bought the summit ones to put on my XS, mabye $15ish
