porting ls6 intake?
Old Nov 20, 2007 | 05:51 PM
shaun's Avatar
Question porting ls6 intake?
hey guys can a ls6 intake be ported? i have read that a ls2 can be ported.
if it can be what would be the gain's?
thanks.
Old Nov 20, 2007 | 07:09 PM
BROKEN's Avatar
i would guess that you could but with your mods it wouldnt prob help
Old Nov 20, 2007 | 07:29 PM
youguessit's Avatar
You cannot port a ls6 intake manifold.
Old Nov 20, 2007 | 07:39 PM
Ace$nyper's Avatar
I know some one/company offers it.
Old Nov 20, 2007 | 09:02 PM
King Nothing's Avatar
thanks.
i'm gettin a dyno tune done on mine in 2 weeks, i'll post up and PM you the results so you can see what i got from being stock to putting a PORTED LS6 manifold on
hmmmm really you sure about that????? read my sig also check this out TPIS porting LS6 you can retract your statement when you come back.
Old Nov 20, 2007 | 11:02 PM
Bullitt4110's Avatar
It can be ported but they are kinda hit and miss on making more snice the stock LS6 runners are pretty good already. You will not see much and may even lose some power if you are not running a larger cam and/or heads. With your mods I wouldnt bother.
Old Nov 21, 2007 | 01:10 PM
RE AND CHERYL's Avatar
Originally Posted by King Nothing
hmmmm really you sure about that????? read my sig you can retract your statement when you come back.
Porting a plastic intake is not really feasable because there is very little material you are able to remove without cutting through. FAST intakes are made with extra material so they can be match ported if necessary.
The TPIS intake is NOT ported. They simply remove the stock mouth and attach one for a 90mm TB. I don't see anything he needs to retract. If that is what you have, It's not ported.
Re'
Old Nov 21, 2007 | 01:55 PM
Re'
check my statement, i didn't say which part TPIS ports and he actually didn't ask specifically which part of the intake can be ported anyway. my runners are ported so my manifold is a ported LS6 manifold and i'm gettin my dyno tune in 2 weeks with good chances that i gained power. so this goes to show it can be ported.
Old Nov 21, 2007 | 02:10 PM
slt200mph's Avatar
Old Nov 21, 2007 | 03:19 PM
sciff5's Avatar
seems kinda expensive. 300 on avg for an ls6 manifold plus 350 for porting... jeesh... at that point you might as well get a fast
Old Nov 21, 2007 | 03:43 PM
KillerZO6's Avatar
they can be ported if to cut the floor out, then u have to seal it back up after it done , also they can be port matched and some runner work can be done to them
Old Nov 21, 2007 | 06:12 PM
my runners were ported
unless you know somebody who can do it . . . at that point it's cheaper
Old Nov 21, 2007 | 06:50 PM
sciff5's Avatar
It may be cheaper, but not by much and the Fast is proven...where as the Poted Ls6 really isnt... I am deff open to people proving me wrong though. If someone posts some graphs with the ported Ls6 showing gains, it would be great for everyone.
Old Nov 22, 2007 | 04:01 PM
well if i was goin with a heads cam i'd think about the FAST but then i'd decide not to get the FAST and wait for the new manifold coming out from weiand next spring
