Anyone running the WS6 lower air box on a Camaro?
Old Jun 20, 2003 | 10:39 PM
Dragaholic's Avatar
9 Second Club NA
Default Anyone running the WS6 lower air box on a Camaro?
I hear that the lower air box on a WS6 is more opened in the front, thats why Im considering using one. I was also wondering what all has to be done in order to use one in a Camaro? The Stealth kit is out of the picture because I just replaced my Whisper lid with a TS&P. Why does the WS6 have a bigger front opening anyway? Thanks
Old Jun 21, 2003 | 12:02 AM
Gev's Avatar
Gev
Default Re: Anyone running the WS6 lower air box on a Camaro?
I am running one. The only way to do it is with an Ultra-Z hood. That hood provides the necessary clearance for the larger intake hole.
Old Jun 21, 2003 | 05:11 PM
Dragaholic's Avatar
9 Second Club NA
Is it possible to use the SS hood with a WS6 lower air box? If so, what has to be done? I want a bigger opening in the front and the WS6 lower box was one of the suggestions. Have any other ideas? Thanks
Old Jun 21, 2003 | 09:59 PM
jimmyblue's Avatar
Moderator
SS hood barely clears the stock Camaro box, less
than 1/4" to spare. The FRA or aftermarket ram
airs that feed the box from the bottom are the
best way to get more cross-section (although the
air slot is about 50% more area already than your
throttle body).
Old Jun 22, 2003 | 04:58 PM
Dragaholic's Avatar
9 Second Club NA
What is better...blocking off the front porting and using the air coming from the Fast Toys ram air kit or open up the front more? If I was to just use the air from the bottom, I would have to block off the front to get the best results from the FTRA and by doing that, they hood will be totally disfunctional. So...one ram air is better than 2? What I mean is, having sealed air coming fromt the FTRA is better than having both air come from the FTRA and the hood? If so, can you explain why? Thanks
Old Jun 23, 2003 | 11:01 AM
Dragaholic's Avatar
9 Second Club NA
To BigBlackZ28: How come you have to run the Ultra Z hood to run the WS6 lower air box? Does the lower air box sit higher than a SS box would? I thought only the opening would be bigger, but how does that affect how high its sits? What Im worried about is if its going to fit without any hitting, rubbing, clearance, or things of that nature. Thanks
Old Jun 26, 2003 | 04:12 PM
oOoLy's Avatar
BigBlackZ28 ............ do you have some pics for the WS6 air box with the Ultra Z hood on camaro ?
Old Jun 30, 2007 | 02:49 PM
z28drag's Avatar
i wish i could help u, i have the same problem..
i am runing the higher box with ultra z hood and the ftra. got air coming in from both ways. dont know if i should close it or leave them open....
