View Poll Results: Aluminum or Plastic
Aluminum intake
23.88%
Plastic intake
76.12%
Voters: 67. You may not vote on this poll
Aluminum vs plastic intake
Old Nov 28, 2007 | 09:00 AM
Viper's Avatar
Default Aluminum vs plastic intake
If you could buy an aluminum intake with a 90 MM throttle body opening
for $500-600, which made within 5 HP of the FAST, would you buy it? If
not, why not? I know heat soak has been brought up as an issue in the past but never really proven.
Old Nov 28, 2007 | 09:07 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Plastic...I watched a guy's track times on a nice summer day REALLY fall off when he started hot lapping the car. After his runs, I went over, and touched the top of it, and it was scalding hot. He lost about 5-6 MPH hot lapping his ride with the Weiand intake.
That, and I've never seen an aluminum intake that ever lived up to the hype it generated. I know that isn't a part of your polling question, but it still has an impact on my thought patterns...
Old Nov 28, 2007 | 09:12 AM
5301113's Avatar
The aluminum intake will soak up the heat more then the (plastic) plus the aluminum is heavier so what you gain in power won't be noticed. Overall the plastic is just not plastic its a combination of matters to be a better performing intake.
Old Nov 28, 2007 | 09:27 AM
BIG_MIKE2005's Avatar
This is totally false.
It's personal preference. Yea, the intake might hold some more heat, but it's not gonna effect HP at WOT. It'll only heat the air minimally if your in stop & go traffic. At WOT there is too much air flowing thru the intake for it to heat the air temps.
If you think the air will be heated enough to hurt performance when it matters, which is at WOT, then you should also complain about Aluminum heads cause the air is in there just as long as it is the intake.
Of coarse there will be people on both sides of the fence on this issue but in the end the result of these threads always come back to user preference. Composite intakes are great for N/A applications, but if your gonna run boost or nitrous I'd suggest a Aluminum for their added strength & modification ability.
Old Nov 28, 2007 | 09:57 AM
COPOSS's Avatar
The FAST has the burst panel for safety when using nitrous if you have a back fire. And it accommodets nitrous nozzles. But if the burst panel is activated is the FAST destroyed ? or is that part replaceable ?
Old Nov 28, 2007 | 10:39 AM
Viper's Avatar
I would think with the aluminum the manufacturers also have more leeway with design vs. plastic. It's also probably cheaper to manufacturer an aluminum one and come to market with it. And for us end users, it's easier to port aluminum and fix it if you make a mistake.
Old Nov 28, 2007 | 11:42 AM
MeentSS02's Avatar
Hang on there professor...
He stated that the aluminum intake will soak up more heat than the plastic piece. That is 100% true. He never said whether or not it would affect performance...
Old Nov 28, 2007 | 12:25 PM
Read my whole quote please, because he does mention that you wouldn't "notice" any power gain with a aftermerket Aluminum intake. And that statement is false.
Old Nov 28, 2007 | 02:35 PM
josh2002-ws6's Avatar
The question at hand is way too vauge. What is the specific application? I agree that a composite (FAST) intake is great for N/A cars. Yes the FAST manifolds come with burst panels but I am pretty sure that is not going to be cheap to fix if a backfire does happen. I also agree that a aluminum intake is the best for nitrous and boost. When hitting the nitrous all the motor will see is a great drop in tempatures anyway so the material of the manifold shouldn't matter as to if it holds heat or not, just if it will hold up for a backfire. The aluminum will soak heat but he is also right that is won't matter too much under WOT. In my opinion I would do a composite manifold for N/A and aluminum for a nitrous or boost car.
Old Nov 28, 2007 | 03:54 PM
RA4926's Avatar
i dont think the material of the manifold matters as much as most on this site seem to think. its an intake manifold...cooler air is constantly flowing through it, dont think heat soak will affect it that much.
Old Nov 28, 2007 | 04:05 PM
bowtierodder's Avatar
heat soak? whats that?, i thought thats what nitrous was made for?
Old Nov 28, 2007 | 04:11 PM
slt200mph's Avatar
ITS BACK!! ... Good I have not beaten a dead horse latey...
Old Nov 28, 2007 | 04:14 PM
MeentSS02's Avatar
Read his whole quote please. He said that the weight difference would offset the negligible gain by "upgrading" to an aluminum intake. Aluminum intakes have only proven themselves to perform on par with an LS6 plastic intake (at least from what I've seen)...so that would make them direct competitors. An aluminum intake weighs more than the plastic LS6. If they have similar power outputs, the heavier intake would put you at a disadvantage, however slight that might be. My logic is most likely flawed, but after a long day of work, it seems to make sense in my head.
If there was an aluminum intake out there that could perform on par with a FAST intake (independent tests, not marketing bullshit), it would be the same issue. Pay more for the FAST, get good performance, and lighter weight, or pay for this mythical aluminum intake, run the risk of heat soak (which you can't prove or disprove at this point), and add weight to your car's schnoz.
Old Nov 28, 2007 | 04:30 PM
I get what your sayin man. But I don't believe the extra couple pounds is really gonna matter unless your tryin to get every extra tenth outta the car every weekend at the track.
There has to be just as many advantages & disadvantages to each seeing as how most guys running in the sub 10 second catagory run sheet metal intakes. Not composite.
But I still stand by my first post.
Composite for a N/A application
Aluminum for boosted or nitrous
Thats why I went Aluminum. I had it all port/polished out & matched to my port/polished heads. Needless to say a decent amount of material has been removed from my Aluminum intake so it should out flow the LS6 at this point. My TB was also ported out to the max & the intake done to match. I also plan on running a 100-150 dry later. Thats the extra versitility advantage of the Aluminum. You can do alot more with them in the end, but again it all falls on personal choice when its all said & done.
Old Nov 28, 2007 | 04:37 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
plastic doesn't absorb the heat as much...
Old Nov 28, 2007 | 04:43 PM
Viper's Avatar
"But I don't believe the extra couple pounds is really gonna matter unless your tryin to get every extra tenth outta the car every weekend at the track"
This is why if someone made an aluminum one AT that price point, I think it would be a winner. Provided it truly performed as advertised.
Old Nov 28, 2007 | 08:02 PM
slowandrichws6's Avatar
plastic kicks ***... only because thats what i have
Old Nov 28, 2007 | 09:32 PM
dirt track racer 81's Avatar
gonna have to agree with my fellow oklahoman here..ive searched and searched this site over aluminum vs plastic and all i find is the same crap abaout aluminum heat soaks and kills power..BUT there has yet to be any one to prove this yet..in my opinion air is going through so fast at wot it doesnt have any time to heat up..just got my professional products intake this week and plan on having it on this weekend and do some dyno tuning on it in a few weeks..im going to do some runs hot and cold and see what it does
Old Dec 3, 2007 | 06:30 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Old Dec 3, 2007 | 08:39 PM
Mean Green z28's Avatar
Ummm another point for plastic ... when you have to do a quick repair, like reaching around the back of the manifold to fool around with some stupid *** vacuum tube that popped loose on the last run ... the aluminum intake with BURN THE SHYT OUT OF YOU !!! lol, happened to me on a friend's car ... although, I don't have a preference right now, Aluminum spider intakes look SEXY!!!
