Anyone with AR Header have this problem?
Old Nov 28, 2007 | 09:33 AM
JScamaro's Avatar
Default Anyone with AR Header have this problem?
I have an annoying rattle of my driver side after installing my AR headers a month or so ago. I noticed today that on the passenger side I can run my fingers around the passenger primaries and have plenty of clearance around the k member.
On the driver side I don't have nearly as much clearance and I think that is causing my rattle.
The rattle is even worse when I am at an incline on the street.
Should I try to adjust them or do I need to grind the k member some to give me more clearance? Has anyone else had this problem?
[IMG][/IMG]
[IMG][/IMG]
Thanks
Old Nov 28, 2007 | 09:54 AM
92SilverSHO's Avatar
My exhaust seems to hang a bit lower than when it was first installed. I can't even put a soda can between the ground and my ypipe and im at stock height.
Old Nov 28, 2007 | 10:18 AM
Redlinez's Avatar
I would recommend a poly driver side engine mount, might help your situtation.
Old Nov 28, 2007 | 12:02 PM
camaroguy26's Avatar
yeah my driver's side hits the k-member but it's only when the engine shakes like when I take off from a stop. the poly motor mounts would probably help but yes you can grind the k-member some. Eventually I'm going to get a tubular k-member to give it more clearance and lose some weight.
Old Nov 28, 2007 | 12:06 PM
2002_z28_m6's Avatar
Mine do tap the k member at W.O.T but its barely noticable. The header is not getting damaged so im going to leave it alone. I plan on going tubular K member anyways.
Old Nov 28, 2007 | 12:21 PM
Jordan S.'s Avatar
I bet poly mounts would fix it. Especially if your stock ones are worn out.
Old Nov 28, 2007 | 01:10 PM
JScamaro's Avatar
Yea it only rattles when at idle not when I'm driving so its not too big of a deal just kind of annoying.
I just looked at the UMI k member and I'll probably get one of those to give some more clearance and lose some weight in the future.
Old Nov 30, 2007 | 01:38 PM
rsodeputy61's Avatar
get up under it and look at the driver's side k member. i bet u a dollar to a donut that it's shiny where it's hittin it when your engine moves. just notch it slightly and it'll quit. i had to do the same. mine did it when i really got on it in first or second. i thought it was my y pipe bangin til the exhaust shop looked at the k member.. good luck!!
Old Nov 30, 2007 | 02:03 PM
99_SS_LS1's Avatar
Curious. I think I am having the same problem. I installed my AR on tuesday, and have only drove the car twice since. I do have a "annoying rattle" usually when I have the wheel turned and am starting in first. I'll have to check out the k-member. Thanks for the advice
Old Nov 30, 2007 | 05:40 PM
LS1 Freak's Avatar
I havent had this problem yet, I have to look at my K member as well! New motor mount should help, keep us updated.
Old Dec 1, 2007 | 10:21 PM
cals400ex's Avatar
i was dead set on these headers. i can't believe these have close clearances like that. my pacesetters fit absolutely great. the tsp y-pipe on the other hand....
Old Dec 1, 2007 | 10:30 PM
NHRArox's Avatar
i havent had that problem, but now im going to check the K member, good luck, dont grind if you can help it. good luck buddy
Old Dec 1, 2007 | 10:47 PM
JScamaro's Avatar
This problem is so minute for me I don't want this to sway anyone away from buying these headers because they are great.
Its really not that big of a deal. Its only a small rattle at idle and it probably really has nothing to do with the header.
They gave great performance and were very easy to install. I only had ~20" of ground clearance and they slid right in.
I'm going to be replacing the front suspension in a month or so anyways so a new k member will be in order as well as some new motor mounts.
Old Dec 2, 2007 | 10:00 AM
02 1LE HAWK's Avatar
I haven't had any issues yet....have great clearance around the K-member.
-Matt
Old Dec 2, 2007 | 12:08 PM
bmax's Avatar
My American Racing headers dont have any issues, your motor mounts are prob the reason.
Brad
Old Dec 2, 2007 | 03:31 PM
JZ28's Avatar
Solid motor mounts.
