Underdrive Pulleys bad according to HPP
Old Jun 24, 2003 | 08:32 PM
WhitePheonix's Avatar
Default Underdrive Pulleys bad according to HPP
Just read my newest HPP, one of the articles was the 15 LS1 upgrade pitfalls you should avoid. They claimed pulleys cause the engine to run hot,also cause the alternator to run slower causing charging problems and can cause problems with the computer pulling timing. What is your experience with pulleys both good and bad?
PS- Im looking to buy a modded 98 WS6 that has pulleys and Im curious
Old Jun 24, 2003 | 08:45 PM
jimmyblue's Avatar
Moderator
Default Re: Underdrive Pulleys bad according to HPP
Running less coolant flow presents a limit to
heat extraction at high power output. You would
find out later whether it's a problem. Same for
the alternator, you make up for less RPM with
more field current at idle or high load (unless
you have two pulleys, crank and alt). Only, the
alt regulator has field current and thermal
limits of its own (my stock '02 is marginal and
drops out of reg on hot days, A/C on, idle).
It's a semi-cheap way to squeeze out ponies but
I prefer solid cooling and power supply; get the
upside from airflow (intake and exhaust) and don't
stiff the waiter, he might spit in your soup.
Old Jun 24, 2003 | 09:44 PM
Skelton's Avatar
Run pullies and forget about it. My 3 ls1's have all had asp pullies and have never run hot or had charging problems. I do recommend a 180 stat though.
Old Jun 24, 2003 | 09:45 PM
jmX's Avatar
jmX
I'd bet that thousands of people a day drive an LS1 car with an underdrive pulley on it and have no issues what so ever. I've had one on mine for the past 3 years in texas heat, WITH a stereo, and never once have I had an issue related to it.
Old Jun 25, 2003 | 08:56 AM
TheDogofWar's Avatar
According to their specs, Idle speed is still enough to give a complete charge (even with the end alt pulley, i think)
As far as cooling, yeah it could under some conditions. Theres a solution for that though, thermostat, fan settings.
Old Jun 25, 2003 | 09:12 AM
00T\A's Avatar
My asp Pulley Rock's , No issues here.
Old Jun 25, 2003 | 11:36 AM
383LQ4SS's Avatar
Pshhh..I have an iron motor living in Fl and had NO cooling problems, even in 100 degree heat in stop and go traffic.
Old Jun 25, 2003 | 11:48 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I autotapped mine and it was fine...
If that's the same HPP article that we've talked about before it's poorly written.
Old Jun 25, 2003 | 02:37 PM
Cal's Avatar
Cal
The only time the alternator may not be putting out enough to charge the battery would be at idle; the rest of the time the voltage regulator is cutting back the alternator output anyway. Since most people increase the idle speed when they install a cam, it won't be a problem for them. As popular as these pulleys are, we should be hearing about it if there are charging or cooling problems. I've also heard power steering pumps are being way over-driven in the stock setup; a pulley will probably help it last longer as well. Lowering the engines parasitic losses is like removing weight from your car; free horsepower.
Old Jun 25, 2003 | 11:29 PM
2001CamaroGuy's Avatar
I like my ASP pulley. I found that my car actually ran COOLER with the underdrive pulley (I live in AZ). By slowing everything down, the engine had less "work" to do (even with the AC on) so it ended up running lower temps.
The think I tell people to make sure they get is the overdrive for the alternator. This will bring it back up to factory speed and prevent charging problems.
Old Jun 26, 2003 | 12:51 AM
mike c.'s Avatar
don't believe everything you read,hundreds of people can't be wrong.i've had NO problems with my asp pullies,going on 2yrs now.
Old Jun 26, 2003 | 12:56 AM
Mike K.'s Avatar
No issues here with mine either. Its been on for about a year, I still have the stock battery and it is green.
Old Jun 26, 2003 | 01:21 PM
TWS's Avatar
TWS
I'm about to put an ASP underdrive on my '99 and have no worries. You should NOT need an overdrive on the alternator unless it is an A4 car.
I have run March pullies on my '94 for years. No problems, although I did have to get the alt. pulley as the '94 has an A4 and only idles at 600 (vs. 900 for my M6 cars).
Old Jun 26, 2003 | 02:06 PM
Pesticide's Avatar
I am having a heck of a time getting my factory crank pulley off. I have loosened the
crank bolt, tried a three prong puller and can get the factory pulley to budge. I am afraid
of tapping the pulley with a hammer and damaging something. Any tips would be greatly appreciated.
Thanks
John
Old Jun 26, 2003 | 03:23 PM
BigPlanTransAm's Avatar
TWS why would an A4 need an overdrive alternator and not an M6?
Old Jun 26, 2003 | 03:46 PM
Cal's Avatar
Cal
Because A4's have a lower idle since they stay in gear even when you come to a stop. A4's also tend to shift sooner and keep rpms down in city traffic, whereas you can buzz your engine as high as you want with a M6. Alternator output is quite sensitive to rpm. Someone with an M6 that boggs the engine all time will have the same problem.
Old Jun 26, 2003 | 05:04 PM
BIG PD's Avatar
cal i have an asp pulley on my auto...it runs perfectly fine.
Old Jun 27, 2003 | 10:40 AM
Cal's Avatar
Cal
I'm not saying he WILL have problems with an auto, just more likely to. Depends on the type of driving also; alot of city driving that involves being stopped at traffic lights with the headlights and other electrical asessories on obviously will pull the battery down. Another bad thing is to start the car and just leaving it sitting idling for an extended period of time.
Old Jun 27, 2003 | 06:17 PM
Thanks
John
don't hit on it.....just get a bigger wrengh (1/2 socket wrench with a long pipe on it) and keep on working it....
Old Jun 27, 2003 | 09:34 PM
gMAG's Avatar
Thanks
John
John, In addition to using the 1/2 inch ratchet w/extension as suggested above, are you checking to make sure the center post on your puller is not riding off center of the crank bolt as you tighten the puller?
A tip given some time ago on this site suggested making an indentation on the center of the crank bolt. This can be accomplished with a small drill bit.
Also, I recall having to play around with the three adjustable fingers on my puller so that equal pressure was being applied to the pulley. Hope this helps!
