Oil On #2 Spark Plug PCV Problem?
Old Dec 17, 2007 | 12:06 AM
1999ssls1's Avatar
Default Oil On #2 Spark Plug PCV Problem?
I have a forged H/C/I 347 with about 700 miles. I have been having a problem recently with oil getting on #2 spark plug and oily threads on all. I use loctite on my rocker arm bolts, if that matters. I done a cam swap today and changed plugs and will check tomorrow and see if it changes with new plugs and loctite. Any ideas?
Thanks
Old Dec 17, 2007 | 03:37 AM
bryan04h's Avatar
my two cents, check the valve cover gasket if it is outside the spark plug...obvious....if it is in the electrode you could have a bad piston ring or maybe just broken/bent pushrods...not an internal genious so no one burn me...
