Will this head setup be enough?
1. Will the stage one heads be able to handle the lift from either cam?
2. Would the performance benefit of going to stage 2 heads be worth the extra investment?
3. Are both cams what most of you would consider street driveable?
Below I will include links to all products so you guys don't have to do a ton of searching. Thanks for all the help, I really appreciate it!
Livernois Stage 1 Heads
Livernois Stage 2 Heads
As all TR cams are on one page I will seperate the info here.
TR227/224-114 = 227/224 .569/.563 114 LSA
TR230/224-111 = 230/224 .575/.563 111 LSA
Thanks again for any and all help!
I would also play it on the safe side and run our stage 2's, we do a little more work to our 2's, so they do actually flow better then advertised (and better then the stage 1's) so there is more then just a spring difference there. Plus if you ever want to grow the stage 2's more capable spring will allow for this.
