View Poll Results: Does your y-pipe bang under the car?
Yes, all the time and it drives me nuts!
8.47%
Yes, but only occasionally and is tolerable.
37.29%
No, I did motor mounts to fix it.
23.73%
No, I used the little hangar rubber things to fix it.
10.17%
No, other way of fixing it(explain).
8.47%
No, I never had a problem with it.
11.86%
Voters: 59. You may not vote on this poll
Y pipe banging
Old Dec 25, 2007 | 10:37 PM
jrob56's Avatar
Question Y pipe banging
How many of you with longtubes and a y-pipe set up have the issue with it banging under the car. If you dont have it did you do motor mounts to cure it or just no problems with it? For all what is your setup(brand lt's, y-pipe, and catback). thanks guys.
edit: another question r u m6 or a4 and could this make a difference?
Old Dec 25, 2007 | 10:56 PM
ryanfx's Avatar
I have pacesetter long tubes with a catted TSP y piped. The banging was driving me insane... to solve it I just shoved a handful of bronze wool in between the floor board and y pipe... hasn't banged once since =D
Old Dec 25, 2007 | 11:42 PM
JScamaro's Avatar
Mine only bangs on hard launches from a dig but I think its mainly because of a broken motor mount.
Old Dec 26, 2007 | 06:10 AM
bryan04h's Avatar
i solved that prob with prothane engine mounts...worked for me
Old Dec 26, 2007 | 08:46 AM
donkey mule's Avatar
Mine does it ocassionaly only under hard acceleration. It is slightly annoying and It is on my to do list.
Old Dec 26, 2007 | 09:17 AM
02 wife's Avatar
I got Kooks Lt installed with cats it bangs! I'm getting the polymounts installed real soon!
Old Dec 26, 2007 | 09:24 AM
WS6_00's Avatar
I have kooks LT's w a custom Y w dynomax bullets. The Y-pipe bangs on hard accelerations and sometimes when I'm turning into a parking lot or something. I've been meaning to shove something in between the Y and floorboard. will poly motor mounts fix the banging? maybe I'll have to get some.
Old Dec 26, 2007 | 09:52 AM
2000SS1979's Avatar
I have never had my "y" pipe bang ever. I have Pacesetter LT's and TSP catted "y". I guess I am just lucky!
Old Dec 26, 2007 | 03:10 PM
lgobraves's Avatar
xs y-pipe bangs. The Y pipe is a piece of junk. I'm going to fix it with a custom y-pipe with a flowmaster merge.
Old Dec 26, 2007 | 03:50 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
when i had stupid cats on..it banged..Both y and cats were hitting..took them off..rearanged it all[ypipe]..none. simple..[ only had cats on for 3 weeks for emissions...should have removed them the same day i put them on..was trying to be responsible.] STUPID CATS.
Old Dec 26, 2007 | 04:00 PM
jzzamesb's Avatar
pacesetter lt's and ory here and it bangs under acceleration in the first two gears only.. Still pisses me off I'll fix it eventually!
Old Dec 26, 2007 | 04:05 PM
grn95t/a's Avatar
my pacestters and ory banged till i put poly mtr mnts in. no more bang thank god!!
Old Dec 26, 2007 | 05:21 PM
radz282003's Avatar
My QTP Y-pipe banged. I had SLP SFCs under the car which made aligning more complicated. I ended-up loosing a cat', so I cut both of them off, hung new 3-inch round cats after of the collectors, got some 3-inch mandrel bent pipe, cut a section to connect the driver's side to the merge collector, and had it welded-up. I ended-up trimming a small section of the floor crossmember above the cat', pushed it up, stuffed a Mufflex hanger in there, no more bangy-bangy.
Old Dec 26, 2007 | 05:38 PM
95 Z28's Avatar
Poly mounts are 50 bucks and they're cake to install with the headers/manifolds out of the way. I did them when I put in my long tubes because I didn't want to screw around with a banging exhaust. Had my TSP ORY, true duals, and now a Pacesetter Y all tucked within 1/2" of the floorboard and it's never made a sound. I don't understand why people will do headers and then take their chances of having a Y pipe cranking their floorboard by not doing motor mounts.
Old Dec 26, 2007 | 06:02 PM
blkbird's Avatar
Mine used to bang alot before the motormounts. After the replacement of them, no more banging issues!!
Old Dec 26, 2007 | 07:22 PM
CAMAROZ28AQUINO's Avatar
Peacesetter longtubes, custome catted Y, and magnaflow catback, Y pipe banged like a prostitute. Poly motor mounts put her in jail and stopped all the banging!
Old Dec 26, 2007 | 08:04 PM
jrob56's Avatar
haha^ i want to do poly mounts before i do my longtubes but im very worried about interior vibration.
Old Dec 26, 2007 | 08:48 PM
ChocoTaco369's Avatar
Tech Resident
Custom y-pipe. Best way to go IMO. No banging, rubbing, etc...
Old Dec 26, 2007 | 11:00 PM
seriously, poly motor mounts are not remotely as bad as you think, in fact there not bad at all. People on these forums tend to "scare" people about certain things like the motor mounts about vibration and there isnt anything to worry about. I have a very very slight, not even noticeable vibration on cold starts when in reverse only. Nothing else changed, trust me by putting them in and you will be as happy as can be. WHen i was researching about poly motor mounts i was also worried about this problem and scared that i would have a ton of vibration in the interior. I just put em in to fix the Y pipe banging, which it did completely with no side affects whatsoever!
Old Dec 27, 2007 | 02:39 AM
slowjoe99's Avatar
if you have a big cam and stall converter and have banging, after installing poly motor mounts will you have a lot of interior vibrations or any more banging?
