Crank Bolt with Auto
Old Jan 1, 2008 | 07:57 PM
00Formula00's Avatar
Default Crank Bolt with Auto
How do you get the bolt cracked if you cant get to the flexplate? I have the tool but I dont see anywhere to put it with the tranny hooked up...
I have a couple of friends saying that an impact gun may work without even having to hold the flexplate
Old Jan 1, 2008 | 08:50 PM
Anyone???
Old Jan 1, 2008 | 09:45 PM
youguessit's Avatar
you meen the bolt that holds the stall on it right? if thats it you can put a screwdriver throught the pulley to hold the crank still
sroach20's Avatar
i hit mine with an impact and the crank bolt came right out.
Old Jan 1, 2008 | 09:47 PM
WE TODD DID's Avatar
Impact.
Old Jan 1, 2008 | 10:26 PM
98Camarod's Avatar
Screwdriver that will not bend easily wedged in there. Thats what I had to do the three times I've done it.
Old Jan 2, 2008 | 12:21 PM
Impact, done, really easily too....If you have an auto impact seemed like the way to go
Old Jan 2, 2008 | 12:46 PM
AFTICA's Avatar
I wedge a breaker bar on the frame and bump the starter. Regardless of how you get it off you'll have to grab the flywheel with a tool or screwdriver to get it back on and torqued to spec.
Old Jan 3, 2008 | 07:24 PM
mikep2002's Avatar
http://forums.corvetteforum.com/show....php?t=1898844 (post #9)
Not sure if I`m breaking the rules but I found this interesting? If I am let me know and I will delete.
