carbon fiber valve covers
SDL002VC
that scoggen dicky sells look real trick. EPP just installed them on there blown orange camaro , they look awesome
but i wanted to find out if they would be good on a street car, how well they fit, seal, and can i mount my stock coil bracket to them.
thanks for your help
You can get the coil brackets from SDPC that bolt right onto these.
Did they come with oil fill cap and will the PCV system all go together , my car is Procharged and i run a ANW catch can
thank you for your help
Im not 100% sure the wires will work, we used truck wires as they are a little bit longer and we had a bit of slack.
It has a oil fill hole with cap, and a 3/8s barb for the breather, it is not in the same place so you will have to figure something out for it.
How much taller are they ? think my wires have some slack , but not much
