Can header and Off Rd Y cause my car to ping (run lean)
Old 07-02-2003, 12:57 AM
Bowtieman4life's Avatar
Default Can header and Off Rd Y cause my car to ping (run lean)
I just installed then and the car is pinging. What do you think?
Thanks
Old 07-02-2003, 01:02 AM
Z-Rated's Avatar
Default Re: Can header and Off Rd Y cause my car to ping (run lean)
Is it hitting the floor board? If so then your getting knock, as for pinging I have no idea. Did you check the easy stuff, like plug wires and the clip to plug up the coil packs? What about the wire to the coil pack itself?
Old 07-03-2003, 05:57 AM
u8dusst's Avatar
Usually after headers you run rich. Strange.
Old 07-03-2003, 12:26 PM
IslandTahoe's Avatar
Maybe more valvetrain noise coming thru the thinner walled header?
Old 07-05-2003, 02:13 PM
Freak's Avatar
I ran real lean after headers and Y, around 14 to 1 accordign the the dyno wideband. so I would say yes, that could happen.
