Getting 210 miles on tank of gas....
Old May 3, 2008 | 10:11 PM
  #121
TopFlite's Avatar
Originally Posted by ArcticZ28
Lucky! I get 12mpg
Same here, except its with the Caddy! With my Z, its closer to 17mpg city with very VERY conservative driving. With 400hp at the crank, i'm happy with that.
Old May 3, 2008 | 10:24 PM
  #122
DrkPhx's Avatar
I just took my car on a hwy cruise and got 16mpg averaging 70 mph. This is with an A4, big stall and 3.73 gears. However the story changes with city driving. If I mix it up, I can squeek out maybe 14-15 mpg. My TB SS gets no better than 14 mpg on hwy.
Old May 5, 2008 | 08:30 AM
  #123
ezzlez28's Avatar
3/4 of a tank so far and 227 miles. Mostly city, maybe about 60 of those are on the freeway. Not bad and I am completely happy with it for now.
Old May 5, 2008 | 08:32 AM
  #124
Nightrydass's Avatar
Originally Posted by noah89
How does anybody constantly shift these cars at 2k rpm? I have absolutely zero nada nil self control I guess.
Originally Posted by WhiteFormula98
10.5 mpg in the city lol....can't keep the foot off the acclerator
...yup!
Old May 5, 2008 | 11:33 AM
  #125
01slowbird's Avatar
i only read the first page and since i didnt see anyone say anything about a couple things i will. first off you have added a ported tb, aka more air in more gas used. you have a custom tune which shouldnt hurt your mileage but in your case may have, change your fuel filter, and finally what plugs did you put in? if you stuck tr55s in then you will suffer gas mileage and overall performance. if you want a better running car and better gas mileage only put ac delco double platinum plugs in. if any of this is a repeat, just disregard what i said and good luck with you mileage problems.
Old May 5, 2008 | 07:41 PM
  #126
OffspringZ28's Avatar
any proof to back this claim up?
Old May 5, 2008 | 10:42 PM
  #127
Grimes's Avatar
Okay guys, calm down, there is an EXACT way to get MPG without running your tank down, and doing some BS estimating mumbojumbo using "about how big the tanks are"
1. Fill up your tank all the way (DO NOT TOP IT OFF, LET THE NOZZLE STOP ON ITS OWN)
2. Reset the trip odometer
3. Drive around (it does not matter how much you run the tank down. 1/2 tank, 1/4 tank, doesn't matter)
4. Go back to the same gas station, same pump, and fill up again, DO NOT TOP OFF
5. Divide the miles on the trip odometer by the number of gallons it just took you to fill up (it's on the pump people)
6. This will give you your EXACT MPG. There is no other accurate way to measure MPG except this way!
There, not so hard was it? That's exact..... no "if", "ands", or "buts" about it.
By the way, I have all the mods in my sig (mostly stock), and drive around like grandma, and still get only 17MPG half highway half city.
Finally, can people please stop using "miles per tank" as a measure of fuel economy? It is utterly ridiculous and inaccurate.
Old May 6, 2008 | 02:45 AM
  #128
LSex's Avatar
I'll probably get the bs flag raised on this one but I use the same method as above and my car consistently gets 18-19mpg city. I've ***** footed it 3 separate times to see how good I could get my city mileage and its consistent, each time mpg was within .2 of others. This is with majority of shifting below 2000rpms and always obeying the skip shift light going from 1st to 4th.
Not bad for a 475rwhp car
Old May 6, 2008 | 08:39 AM
  #129
jam01's Avatar
wow im getting under 200 per tank. and it is stock.
Old May 6, 2008 | 02:00 PM
  #130
Grimes's Avatar
I definitely believe you....
Old May 6, 2008 | 03:03 PM
  #131
Jigen's Avatar
Originally Posted by BackinBlack02SS
In the real world, we determine miles per tank based on how many miles you have driven from the time you last filled your tank up to the time you were required to refill the tank again. You can't seem to grasp this concept, so I will leave you to continue spreading your misinformation.
The only thing is that your concept is broken, real world or not. Like Choco and the others said, the only way to get an accurate number to miles per tank is by finding out your MPG and then multiplying that by your tank's size.
Example:
- I fill up my gas tank.
- I put 200 miles on that one fill up.
- When I go to fill up again it takes 10 gallons to fill the tank.
- I divide 200 into 10 and get 20. This is my MPG.
- My gas tank is 16.8 gallons.
- 16.8 times 20 = 336
- That is my Miles Per Tank
I just don't get how people can argue this method.
Old May 6, 2008 | 03:52 PM
  #132
Kingc8r's Avatar
My best was 24 mpgs, all freeway. DD I average between 17-19 sepending on how many times i get a heavy foot....I'd say nothing is wrong with your car. People on here just post inflated numbers
Old May 6, 2008 | 04:30 PM
  #133
LilJayV10's Avatar
If shifting below 2 grand every time and going from 1st to 4th gear. I will never get 25mpg. It's just not going to happen.
Old May 6, 2008 | 11:34 PM
  #134
BackinBlack02SS's Avatar
Example:
I'm not disputing what you are saying. Besides different size tanks, it's just not logical to use MPT as a way of measuring fuel economy. Does it make sense to determine average fuel economy based on how many miles you can possibly get out of one tank of fuel? That means you have to run empty to achieve those numbers. That is why MPT is not used in the real world. MPG is the only sensible way to determine fuel economy. BTW, when the people on here are giving out MPT numbers, I'll bet they are referring to how many miles between fill ups.
Old Jun 18, 2009 | 07:51 PM
  #135
scites's Avatar
im getting about 180 to 200 miles to a tank with the 402 with 11.7.1cp and a big cam..
Old Jun 19, 2009 | 03:41 AM
  #136
DaddySS's Avatar
Since you're in southern NJ - why not go SLP, EC superchargers, etc. and get the car tuned for both drivability AFR, and power. I'm sure you'll see a good improvement.
Old Jul 12, 2010 | 11:45 AM
  #137
Wimimc's Avatar
usually when its a lil lower than 1/4 tank i'm at about 200 miles.
i just filled up
199.2 miles on the odometer
i already forgot how much gas i got but my "all around mileage" was 17
Old Jul 12, 2010 | 11:54 AM
  #138
CoreyD's Avatar
i get about 200 to the tank with 95% city driving
Old Jul 12, 2010 | 12:22 PM
  #139
Arc00TA's Avatar
My car gets poor gas mileage compared to my old car, which was much more heavily modded. Heres what I saw:
1999 T/A with LS6, 224 cam, 17x11 wheels and big tires, Long tubes, 3.73's, etc. 425rwhp, consistently averaged 22-24mpg with the fill-drive-fill-devide method, and long highway trips could get up to 28mpg.
1998 formula with stock motor, LT's only, granny 16x8 wheels, and 3.23 stock A4 gears with an M6 consistently averages 16-18mpg, long highway trips get even LOWER to about 10-12mpg.
I think the difference is the old car was well tuned on a dyno and the current car is only semi-tuned, I haven't got a chance to pick up a wideband to tune the AFR correctly either.
Old Jul 12, 2010 | 12:35 PM
  #140
mxmccarter2401's Avatar
anybody notice this was from like a year and a couple of months ago?
