AC Delete
Old Jul 31, 2008 | 12:26 AM
  #101
jetlag's Avatar
Originally Posted by bww3588
highly doubt it, it took me 30 minutes to figure out how i was going to cut the box off the wall.
Did you cut it with the motor in the car? It looks impossible... Damn LS1s.
Old Jul 31, 2008 | 08:52 AM
  #102
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
You can still keep the heater and take the outer half of the box off.
Old Jul 31, 2008 | 08:55 AM
  #103
landonew's Avatar
Originally Posted by AKNUFMAN
Does anyone know where to get a sheet metal plate to cover up the hole if you remove the ac from a 76 Nova? Thanks..........................
BMR sells one for like $70-80. I would just buy that one. Making your own sounds like a pain in the ***, and i hate FAB work.
Old Aug 18, 2008 | 02:23 PM
  #104
Havok2's Avatar
TTT of those wanting to do this (like me)
Old Oct 9, 2008 | 12:38 PM
  #105
dutinsss's Avatar
can somebody explain why you need an ac delete pulley? i read in some other threads that it was required but i don't see why since only the ac is run by that belt.
Old Oct 9, 2008 | 12:49 PM
  #106
waterbug1999's Avatar
Nice quote in your sig.. lol
I dont know what they are referring to.. Usually when people do this they just take the whole compressor off and yea, its has its on belt/inside pulley.
Old Oct 9, 2008 | 12:55 PM
  #107
dutinsss's Avatar
haha, sound familiar?
that's what i was thinking. maybe lt1's ac belts run another accessory also and that was what they were talking about. i don't know. i never use my ac so i'm considering taking mine off and just wanted to make sure.
Old Oct 9, 2008 | 04:03 PM
  #108
Z28/2002's Avatar
Yes you need one on the LT1 cars but NOT on the LS cars
 Michael S. Palmer
Old Oct 31, 2008 | 05:21 AM
  #109
Black_Hawk_02's Avatar
So we just need a shorter belt?
What size?
Old Nov 2, 2008 | 10:00 PM
  #110
bww3588's Avatar
no, you just take the AC belt off.
Old Nov 2, 2008 | 11:05 PM
  #111
thanks... i cant believe, i didnt notice that. I just tore that crap off.
Old Nov 3, 2008 | 11:05 AM
  #112
Ilikeppie's Avatar
Yeah with the LS1 you only need a smaller belt if you go with a under drive pulley
Old Mar 21, 2009 | 06:13 PM
  #113
WS6 Canada's Avatar
I have a problem,
I have removed the AC part of the box from under the hood, and put on a BMR HVAC plate. The vents all switch fine but when i go from heat to cool (vent) I always seem to get heat??? I watched the cable drive move the door from under dash and it seems to work.
Is there anything else I should look for??? or is this the way it is with the mod.
Thanks
CW
Old Mar 21, 2009 | 10:24 PM
  #114
that's weird, and you sure it worked before? Taking the AC crap out shouldn't keep you from getting normal outside temp air when turned to the blue, cold side.
Old Mar 21, 2009 | 11:47 PM
  #115
Sammyboy's Avatar
Originally Posted by WS6 Canada
I have a problem,
Thanks
CW
It is probably just hot outside!!!!
Old Mar 22, 2009 | 10:18 AM
  #116
WS6 Canada's Avatar
It just snowed a foot, it is not hot in my garage.....
Ya, it worked before
Is there a way to get in there without pulling the delete plate.
Old Mar 22, 2009 | 01:11 PM
  #117
i think it has nothing to do with what you did... Maybe the thermostat switch took a dump on ya. See how much a new is and try it, if its not it just take it back.
Old Mar 22, 2009 | 06:54 PM
  #118
WS6 Canada's Avatar
where is that switch located.
Thanks
Old Mar 22, 2009 | 09:06 PM
  #119
Thanks
I was just referring to the **** you turn from cold to hot out of your dash, alls that is is a reostate/pot (maybe im wrong) and those go bad... Honestly, I have no clue why you have what you have but thats what i would do/start on.
