AC Delete
Old Jan 16, 2008 | 11:00 PM
  #61
Ilikeppie's Avatar
alright ill do it where did you get the plate?
Old Jan 16, 2008 | 11:12 PM
  #62
waterbug1999's Avatar
I know a few of the vendors sale the piece... I made a cardboard template and then cut it out of some sheet metal I bought from Home Depot for 5 bucks....
If you dont feel confident in doing it then dont. I am a pretty crafty person and made it myself, cant even tell after all said and done.
Old Jan 16, 2008 | 11:23 PM
  #63
Ilikeppie's Avatar
good idea the only one i found was from bmr and it doesnt look like it has the hole for the heater hoses what did you use to seal it up some kind of caulking?
Old Jan 16, 2008 | 11:32 PM
  #64
Yea, I used some white caulking.
Old Jan 16, 2008 | 11:39 PM
  #65
Ilikeppie's Avatar
what did you use to cut the sheet metal a jig saw with metal blade grinder with a cutting wheel
Old Jan 16, 2008 | 11:49 PM
  #66
FiredUpZ28's Avatar
Originally Posted by SSMOKIN_Y2KSS
i would never want to delete my ac...what am i gonna do in the staging lanes...sweat? thats out cant be sitting there sweating i wanna be nice and cool
For real? AC makes the engine run hotter dude! Keep your windows down until you roll up to the burnout box.
Old Jan 16, 2008 | 11:50 PM
  #67
Some tin snips.
Old Jan 16, 2008 | 11:54 PM
  #68
Ilikeppie's Avatar
caveman style i like it!
 Michael S. Palmer
Old Jan 16, 2008 | 11:57 PM
  #69
It came out good for me with functioning heat.. All my buds think it came out awesome.
Old Jan 17, 2008 | 12:05 AM
  #70
Ilikeppie's Avatar
yea it looks great after i get mine done ill throw some pics up
Old Jan 17, 2008 | 12:15 AM
  #71
chuckyt1's Avatar
I pulled the entire box out with the engine in the car, heads on and all. You could get that box out easy the way your motor sits now. BTW, there is a heater that plugs into your cig lighter if you want to go that way. Also, I think Burkhart makes a block off plate. I made mine out of aluminum and screwed it into th firewall.
Old Jan 17, 2008 | 12:19 AM
  #72
Ilikeppie's Avatar
how did you get the box out i have been looking at it and it looks like i would have to take the dash apart and take it out that way
Old Jan 17, 2008 | 12:27 AM
  #73
Id like to know as well..
In your sig is says you have a 94, maybe those are different then the 98+.
Old Jan 17, 2008 | 12:29 AM
  #74
chuckyt1's Avatar
Been a while so you might want to verify this but... There are some bolts on the firewall side and some under the dash inside the car. Just have to scrape away some "goo" to get to 'em. Lots of extensions and gear wrenches help. Pulling the dash is a lot easier than it looks. I did it when I yanked the passenger side airbag. Lot's of 7 mil bolts... To be honest, I don't remeber if I pulled the dash to get the heater box out. I do remeber what a bitch one of the bolts on the firewall was with the headers in the way...
Old Jan 17, 2008 | 12:36 AM
  #75
chuckyt1's Avatar
Okay, since my memory sucks, I went digging through some parts and found a HVAC box. It looks like it has to come out through the interior. I think you'd have to pull the dash for that. So.... Might as well get rid of that airbag while you're at it...
  #76
LOL.... Yea, I remember looking around and looking around and looking around.. then finally say **** it and just cut that sucker straight up from the firewall. Only took about an hour to get it ripped out.
Then about a half a day to get the metal, cut it, screw it up and paint it and seal it.
Old Jan 17, 2008 | 12:38 AM
  #77
If you pull the HVAC box out, that would mean that you have no heating options correct?
Old Jan 17, 2008 | 12:41 AM
  #78
Ilikeppie's Avatar
yea that shounds about right i think ill cut it plus i want to go ahead and keep the air bags for now its not a full blown race car yet
Old Jan 17, 2008 | 12:47 AM
  #79
When you do start it... As I said before, you will see a small *** hard hose running up thru the area. Dont cut it. Its a vacum hose to where you can change from vent to floor, etc... I made the mistake of tearing that out, then realizing what it was and had to put it back in.
Old Jan 17, 2008 | 12:54 AM
  #80
Ilikeppie's Avatar
is that inside the box?
