What Vortec engines are all aluminum?
Many Vortec engines are are for sale. I Often read "All aluminum".
Please tell me what Vortec engines are aluminum-block engines and if they also have alu-heads.
How can I detect the alu-engines.
Thanks Hannes
Thanks Hannes
Location: Your girl's back door giving her the long stroke while you're at work
Check the link below. As far as I know none of the Vortec motors were aluminum
http://www.mortec.com/castnum.htm
From Mortec, these are the only aluminum blocks GM produced
366298...................4...Bowtie, Aluminum, billet main caps, 3.398" bore with sleeves, two piece rear main seal.
366299...................4...Bowtie, Aluminum, nodular iron splayed caps, wet sump, 4.00" bore
10049804.................4...Aluminum, Pontiac Super Duty version of Gen.I SBC, 4.00" bore, 350 mains, 2-piece rear seal, splayed caps, GTP race block
10134398.................4...Bowtie, Aluminum, 4.125" bore, 2.65" main journals
10134996.................4...Bowtie, Aluminum, 4.125" bore 2.65" main journals
12550592...350...97-up...crossbolted block, Gen.III, "LS1", aluminum
12559378...350...99-up...crossbolted block, Gen.III, "LS1", aluminum
12559846...350...98-up...crossbolted block, Gen.III, "LS1", aluminum
12560621...350...98-up...crossbolted block, Gen.III, "LS1", aluminum
12560626...350...99-up...crossbolted block, Gen.III, "LS1", aluminum
12560629...350...99......crossbolted block, Gen.III, "LS1", aluminum
12561168...350...01-up...crossbolted block, Gen.III, "LS1", aluminum
12562174...350...98-up...crossbolted block, Gen.III, "LS1", aluminum
12568952...364...05-up...crossbolted block, Gen.III, 6.0L, aluminum, LS2
12566910...325...04-up...crossbolted block, Gen.III, 5.3L, aluminum, SSR truck
12571048...325...04-up...crossbolted block, Gen.III, 5.3L
