Help Surgeing
Old Jan 21, 2008 | 03:54 PM
WhiteFormula98's Avatar
Default Help Surgeing
Ok, I just had my throttle body ported, and put it back on any reason would this cause surging?
Old Jan 21, 2008 | 04:05 PM
transAm-98's Avatar
Check your IAC valve and make sure the O ring is on there still, or maybe the adjuster screw on the throttle stop got tampered with.
Old Jan 21, 2008 | 04:59 PM
Shawn @ VA Speed's Avatar
make sure you dont have any vacuum leaks,hose not on or something like that
Old Jan 21, 2008 | 07:23 PM
jimmyblue's Avatar
Moderator
If the IAC is restricted (like epoxy) that will make the idle
unstable whenever the motor wants more air than the IAC
can give. Been there. Conversely if there is too much air
getting past the blade, the IAC will bury trying to choke
something that it has no authority over.
Old Jan 22, 2008 | 04:49 AM
transAm-98's Avatar
Also as stated above, if he ported around the blade or knife edged the throttle blade that could cause a problem.
Old Jan 22, 2008 | 05:44 AM
02 BLK WS6's Avatar
If done properly knife edging will not affect the temperment of the car.
Old Jan 22, 2008 | 07:00 AM
agreed
Old Jan 23, 2008 | 08:27 PM
transAm-98's Avatar
I agree too, IF DONE PROPERLY , but let's face it **** happens sometimes
